Hello all,
So first off thank you to the community for assisting me in other posts! I wanted to share my pistons to hopefully help someone else who is trying to do complex lighting based on lux, location status and special event status. Since I have complex custom lighting solution I created in certain areas of the house I decided to leverage a "Normal- " piston so I only have to configure one piston when I want to change colors for all piston related events for those lights. Feedback is always welcomed too btw!
Lights - Kitchen v2 (Uses Bosch Sensor)
- Motion Sensor 6 - Bosch Motion Sensor
- Motion Sensor
- Contact Sensor 3 - Patio Door Sensor
- Motion Sensor 1 - Living Room Zooz 4-n-1 with Lux Sensor
- Dimmer 5/6 - Main standard Zooz Switch lamps above Kitchen Island and Kitchen Table
- Motion Sensor 8 - Simulated Motion Detector for Bosch lack of inactivity notification
- RGB Bulb 8/9 - Upper/Lower Cabinet LED Light Strips
Lights - Living Room v2 (Uses Zooz 4-n-1 Motion Detector)
- Outlet 2 - WeMo Power meter to check if TV is really on
- RGB Bulb 5 - Fireplace TP-Link Bulbs
- RGB Bulb 6 - Living Room Lamp TP-Link Bulbs
- White Bulbs 4 - Living room ceiling fan light
- Motion Sensor 1 - Zooz 4-n-1 Motion Sensor
Lights - Dining Room v2
- Motion Sensor 3 - EcoLink Motion Sensor
- Motion Sensor 1 - Zooz 4-n-1 LUX from Living Room
- Dimmer 2/3 - Standard Zooz switched lights
