I’ve changed the piston ever so slightly but its made no difference. New log attached too.
23/01/2019, 09:47:58 +95ms
+0ms ╔Received event [Home].time = 1548236879772 with a delay of -1678ms
+182ms ║RunTime Analysis CS > 21ms > PS > 70ms > PE > 91ms > CE
+185ms ║Runtime (45778 bytes) successfully initialized in 70ms (v0.3.109.20181207) (184ms)
+186ms ║╔Execution stage started
+209ms ║║Cancelling condition #12’s schedules…
+210ms ║║Condition #12 evaluated true (2ms)
+217ms ║║Comparison (boolean) true is (boolean) true = true (2ms)
+220ms ║║Condition #13 evaluated true (8ms)
+230ms ║║Comparison (enum) open is (string) open = true (2ms)
+233ms ║║Condition #40 evaluated true (11ms)
+234ms ║║Cancelling condition #8’s schedules…
+236ms ║║Condition group #8 evaluated true (state changed) (28ms)
+239ms ║║Cancelling statement #9’s schedules…
+248ms ║║Skipped execution of physical command [Bathroom Spot 1].off([]) because it would make no change to the device. (2ms)
+249ms ║║Executed [Bathroom Spot 1].off (6ms)
+255ms ║║Skipped execution of physical command [Bathroom Spot 2].off([]) because it would make no change to the device. (3ms)
+256ms ║║Executed [Bathroom Spot 2].off (5ms)
+262ms ║║Skipped execution of physical command [Bathroom Spot 3].off([]) because it would make no change to the device. (3ms)
+264ms ║║Executed [Bathroom Spot 3].off (5ms)
+270ms ║║Skipped execution of physical command [Bathroom Spot 4].off([]) because it would make no change to the device. (3ms)
+272ms ║║Executed [Bathroom Spot 4].off (6ms)
+296ms ║║Condition #18 evaluated false (20ms)
+298ms ║║Condition group #14 evaluated false (state did not change) (21ms)
+351ms ║║Condition #26 evaluated false (49ms)
+353ms ║║Condition group #23 evaluated false (state did not change) (52ms)
+356ms ║╚Execution stage complete. (170ms)
+358ms ╚Event processed successfully (359ms)
23/01/2019, 09:45:59 +576ms
+1ms ╔Received event [Home].test = 1548236759575 with a delay of 1ms
+147ms ║RunTime Analysis CS > 21ms > PS > 45ms > PE > 81ms > CE
+151ms ║Runtime (45772 bytes) successfully initialized in 45ms (v0.3.109.20181207) (148ms)
+152ms ║╔Execution stage started
+168ms ║║Condition #5 evaluated false (8ms)
+170ms ║║Condition group #1 evaluated false (state did not change) (10ms)
+184ms ║║Comparison (enum) inactive stays (string) inactive = true (2ms)
+195ms ║║Adding a timed trigger schedule for condition 12
+201ms ║║Cancelling condition #12’s schedules…
+202ms ║║Condition #12 evaluated false (28ms)
+204ms ║║Cancelling condition #8’s schedules…
+205ms ║║Condition group #8 evaluated false (state changed) (32ms)
+231ms ║║Condition #18 evaluated false (22ms)
+233ms ║║Condition group #14 evaluated false (state did not change) (24ms)
+258ms ║║Condition #26 evaluated false (20ms)
+260ms ║║Condition group #23 evaluated false (state did not change) (22ms)
+272ms ║╚Execution stage complete. (121ms)
+279ms ║Setting up scheduled job for Wed, Jan 23 2019 @ 9:47:59 AM GMT (in 119.918s)
+288ms ╚Event processed successfully (287ms)
23/01/2019, 09:44:34 +715ms
+1ms ╔Starting piston… (v0.3.109.20181207)
+308ms ║╔Subscribing to devices…
+352ms ║║Subscribing to Bathroom Sensor.motion…
+366ms ║║Subscribing to Bathroom Spot 1.switch…
+382ms ║║Subscribing to Bathroom Spot 2.switch…
+394ms ║║Subscribing to Bathroom Spot 3.switch…
+407ms ║║Subscribing to Bathroom Spot 4.switch…
+502ms ║║Subscribing to Bathroom Door…
+504ms ║╚Finished subscribing (211ms)
+575ms ║Comparison (enum) off is (string) off = true (2ms)
+579ms ║Cancelling condition #6’s schedules…
+593ms ║Comparison (string) :85be758d258a40390d4eeb1504b3b5c4: is_not (string) :85be758d258a40390d4eeb1504b3b5c4: = false (3ms)
+595ms ║Cancelling condition #39’s schedules…
+660ms ║Comparison (enum) inactive stays (string) inactive = true (3ms)
+672ms ║Comparison (boolean) true is (boolean) true = true (4ms)
+687ms ║Comparison (enum) open is (string) open = true (3ms)
+734ms ║Comparison (boolean) false is (boolean) true = false (3ms)
+737ms ║Cancelling condition #30’s schedules…
+739ms ║Cancelling condition #27’s schedules…
+788ms ╚Piston successfully started (788ms)
23/01/2019, 09:02:59 +109ms
+1ms ╔Received event [Home].time = 1548234180408 with a delay of -1300ms
+312ms ║RunTime Analysis CS > 81ms > PS > 164ms > PE > 67ms > CE
+315ms ║Runtime (45568 bytes) successfully initialized in 164ms (v0.3.109.20181207) (312ms)
+316ms ║╔Execution stage started
+338ms ║║Cancelling condition #12’s schedules…
+340ms ║║Condition #12 evaluated true (2ms)
+347ms ║║Comparison (boolean) true is (boolean) true = true (2ms)
+350ms ║║Condition #13 evaluated true (8ms)
+360ms ║║Comparison (enum) open is (string) open = true (2ms)
+362ms ║║Condition #40 evaluated true (11ms)
+364ms ║║Cancelling condition #8’s schedules…
+365ms ║║Condition group #8 evaluated true (state changed) (28ms)
+368ms ║║Cancelling statement #9’s schedules…
+378ms ║║Skipped execution of physical command [Bathroom Spot 1].off([]) because it would make no change to the device. (3ms)
+379ms ║║Executed [Bathroom Spot 1].off (6ms)
+386ms ║║Skipped execution of physical command [Bathroom Spot 2].off([]) because it would make no change to the device. (3ms)
+387ms ║║Executed [Bathroom Spot 2].off (5ms)
+393ms ║║Skipped execution of physical command [Bathroom Spot 3].off([]) because it would make no change to the device. (3ms)
+395ms ║║Executed [Bathroom Spot 3].off (6ms)
+401ms ║║Skipped execution of physical command [Bathroom Spot 4].off([]) because it would make no change to the device. (4ms)
+403ms ║║Executed [Bathroom Spot 4].off (6ms)
+428ms ║║Condition #18 evaluated false (20ms)
+430ms ║║Condition group #14 evaluated false (state did not change) (23ms)
+455ms ║║Condition #26 evaluated false (20ms)
+457ms ║║Condition group #23 evaluated false (state did not change) (23ms)
+460ms ║╚Execution stage complete. (144ms)
+462ms ╚Event processed successfully (463ms)
23/01/2019, 09:01:00 +388ms
+2ms ╔Received event [Bathroom Spot 4].switch = off with a delay of 401ms
+10150ms ║RunTime Analysis CS > 15ms > PS > 10072ms > PE > 62ms > CE
+10151ms ║Piston waited at a semaphore for 10019ms
+10154ms ║Runtime (45647 bytes) successfully initialized in 10072ms (v0.3.109.20181207) (10151ms)
+10155ms ║╔Execution stage started
+10170ms ║║Condition #5 evaluated false (7ms)
+10171ms ║║Condition group #1 evaluated false (state did not change) (10ms)
+10184ms ║║Comparison (enum) inactive stays (string) inactive = true (2ms)
+10187ms ║║Condition #12 evaluated false (11ms)
+10188ms ║║Condition group #8 evaluated false (state did not change) (14ms)
+10212ms ║║Comparison (enum) off changes_to (string) on = false (0ms)
+10214ms ║║Condition #18 evaluated false (23ms)
+10216ms ║║Condition group #14 evaluated false (state did not change) (24ms)
+10234ms ║║Comparison (enum) off changes_to (string) off = false (1ms)
+10237ms ║║Condition #26 evaluated false (18ms)
+10238ms ║║Condition group #23 evaluated false (state did not change) (19ms)
+10241ms ║╚Execution stage complete. (85ms)
+10242ms ║Setting up scheduled job for Wed, Jan 23 2019 @ 9:03:00 AM GMT (in 109.778s)
+10254ms ╚Event processed successfully (10254ms)
23/01/2019, 09:01:00 +290ms
+1ms ╔Received event [Bathroom Spot 3].switch = off with a delay of 355ms
+10165ms ║RunTime Analysis CS > 21ms > PS > 10079ms > PE > 65ms > CE
+10166ms ║Piston waited at a semaphore for 10041ms
+10169ms ║Runtime (45647 bytes) successfully initialized in 10079ms (v0.3.109.20181207) (10167ms)
+10170ms ║╔Execution stage started
+10185ms ║║Condition #5 evaluated false (9ms)
+10186ms ║║Condition group #1 evaluated false (state did not change) (11ms)
+10198ms ║║Comparison (enum) inactive stays (string) inactive = true (2ms)
+10200ms ║║Condition #12 evaluated false (11ms)
+10202ms ║║Condition group #8 evaluated false (state did not change) (12ms)
+10222ms ║║Comparison (enum) off changes_to (string) on = false (1ms)
+10225ms ║║Condition #18 evaluated false (19ms)
+10226ms ║║Condition group #14 evaluated false (state did not change) (22ms)
+10245ms ║║Comparison (enum) off changes_to (string) off = false (0ms)
+10247ms ║║Condition #26 evaluated false (18ms)
+10249ms ║║Condition group #23 evaluated false (state did not change) (19ms)
+10251ms ║╚Execution stage complete. (81ms)
+10253ms ║Setting up scheduled job for Wed, Jan 23 2019 @ 9:03:00 AM GMT (in 109.866s)
+10264ms ╚Event processed successfully (10264ms)
23/01/2019, 09:01:00 +162ms
+1ms ╔Received event [Bathroom Spot 1].switch = off with a delay of 356ms
+9665ms ║RunTime Analysis CS > 27ms > PS > 9567ms > PE > 72ms > CE
+9666ms ║Piston waited at a semaphore for 9518ms
+9669ms ║Runtime (45639 bytes) successfully initialized in 9567ms (v0.3.109.20181207) (9667ms)
+9670ms ║╔Execution stage started
+9684ms ║║Condition #5 evaluated false (8ms)
+9685ms ║║Condition group #1 evaluated false (state did not change) (9ms)
+9698ms ║║Comparison (enum) inactive stays (string) inactive = true (2ms)
+9701ms ║║Condition #12 evaluated false (12ms)
+9702ms ║║Condition group #8 evaluated false (state did not change) (14ms)
+9724ms ║║Comparison (enum) off changes_to (string) on = false (1ms)
+9727ms ║║Condition #18 evaluated false (20ms)
+9729ms ║║Condition group #14 evaluated false (state did not change) (23ms)
+9761ms ║║Comparison (enum) off changes_to (string) off = false (1ms)
+9765ms ║║Cancelling condition #26’s schedules…
+9766ms ║║Condition #26 evaluated false (33ms)
+9767ms ║║Cancelling condition #23’s schedules…
+9768ms ║║Condition group #23 evaluated false (state changed) (36ms)
+9771ms ║╚Execution stage complete. (101ms)
+9773ms ║Setting up scheduled job for Wed, Jan 23 2019 @ 9:03:00 AM GMT (in 110.474s)
+9783ms ╚Event processed successfully (9783ms)
23/01/2019, 09:01:00 +232ms
+1ms ╔Received event [Bathroom Spot 2].switch = off with a delay of 377ms
+139ms ║RunTime Analysis CS > 20ms > PS > 55ms > PE > 63ms > CE
+141ms ║Runtime (45564 bytes) successfully initialized in 55ms (v0.3.109.20181207) (139ms)
+143ms ║╔Execution stage started
+158ms ║║Condition #5 evaluated false (9ms)
+159ms ║║Condition group #1 evaluated false (state did not change) (11ms)
+172ms ║║Comparison (enum) inactive stays (string) inactive = true (2ms)
+175ms ║║Adding a timed trigger schedule for condition 12
+178ms ║║Cancelling condition #12’s schedules…
+180ms ║║Condition #12 evaluated false (16ms)
+181ms ║║Cancelling condition #8’s schedules…
+182ms ║║Condition group #8 evaluated false (state changed) (20ms)
+205ms ║║Comparison (enum) off changes_to (string) on = false (0ms)
+208ms ║║Condition #18 evaluated false (21ms)
+209ms ║║Condition group #14 evaluated false (state did not change) (24ms)
+227ms ║║Comparison (enum) off changes_to (string) off = true (1ms)
+230ms ║║Cancelling condition #26’s schedules…
+231ms ║║Condition #26 evaluated true (19ms)
+232ms ║║Cancelling condition #23’s schedules…
+233ms ║║Condition group #23 evaluated true (state changed) (21ms)
+236ms ║║Cancelling statement #24’s schedules…
+244ms ║║Executed virtual command setVariable (4ms)
+248ms ║╚Execution stage complete. (105ms)
+250ms ║Setting up scheduled job for Wed, Jan 23 2019 @ 9:03:00 AM GMT (in 119.927s)
+258ms ╚Event processed successfully (258ms)
23/01/2019, 09:00:59 +360ms
+1ms ╔Received event [Home].time = 1548234054578 with a delay of 4781ms
+559ms ║RunTime Analysis CS > 138ms > PS > 344ms > PE > 78ms > CE
+562ms ║Runtime (45568 bytes) successfully initialized in 344ms (v0.3.109.20181207) (560ms)
+564ms ║╔Execution stage started
+585ms ║║Cancelling condition #12’s schedules…
+586ms ║║Condition #12 evaluated true (2ms)
+594ms ║║Comparison (boolean) true is (boolean) true = true (2ms)
+596ms ║║Cancelling condition #13’s schedules…
+597ms ║║Condition #13 evaluated true (10ms)
+608ms ║║Comparison (enum) open is (string) open = true (2ms)
+611ms ║║Condition #40 evaluated true (13ms)
+613ms ║║Cancelling condition #8’s schedules…
+614ms ║║Condition group #8 evaluated true (state changed) (31ms)
+618ms ║║Cancelling statement #9’s schedules…
+647ms ║║Executed physical command [Bathroom Spot 1].off() (23ms)
+648ms ║║Executed [Bathroom Spot 1].off (26ms)
+672ms ║║Executed physical command [Bathroom Spot 2].off() (21ms)
+674ms ║║Executed [Bathroom Spot 2].off (23ms)
+699ms ║║Executed physical command [Bathroom Spot 3].off() (21ms)
+701ms ║║Executed [Bathroom Spot 3].off (24ms)
+725ms ║║Executed physical command [Bathroom Spot 4].off() (21ms)
+727ms ║║Executed [Bathroom Spot 4].off (24ms)
+758ms ║║Condition #18 evaluated false (24ms)
+760ms ║║Condition group #14 evaluated false (state did not change) (27ms)
+788ms ║║Condition #26 evaluated false (23ms)
+790ms ║║Condition group #23 evaluated false (state did not change) (25ms)
+794ms ║╚Execution stage complete. (231ms)
+796ms ╚Event processed successfully (796ms)
23/01/2019, 08:58:54 +428ms
+1ms ╔Received event [Bathroom Sensor].motion = inactive with a delay of 118ms
+118ms ║RunTime Analysis CS > 18ms > PS > 40ms > PE > 60ms > CE
+121ms ║Runtime (45569 bytes) successfully initialized in 40ms (v0.3.109.20181207) (118ms)
+122ms ║╔Execution stage started
+133ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+135ms ║║Condition #5 evaluated false (6ms)
+136ms ║║Condition group #1 evaluated false (state did not change) (8ms)
+146ms ║║Comparison (enum) inactive stays (string) inactive = true (2ms)
+149ms ║║Adding a timed trigger schedule for condition 12
+152ms ║║Condition #12 evaluated false (12ms)
+153ms ║║Condition group #8 evaluated false (state did not change) (14ms)
+177ms ║║Condition #18 evaluated false (20ms)
+178ms ║║Condition group #14 evaluated false (state did not change) (22ms)
+200ms ║║Condition #26 evaluated false (17ms)
+201ms ║║Condition group #23 evaluated false (state did not change) (20ms)
+204ms ║╚Execution stage complete. (82ms)
+206ms ║Setting up scheduled job for Wed, Jan 23 2019 @ 9:00:54 AM GMT (in 119.945s)
+214ms ╚Event processed successfully (213ms)
23/01/2019, 08:58:46 +88ms
+0ms ╔Received event [Home].time = 1548233926953 with a delay of -866ms
+207ms ║RunTime Analysis CS > 53ms > PS > 74ms > PE > 81ms > CE
+211ms ║Runtime (45562 bytes) successfully initialized in 74ms (v0.3.109.20181207) (209ms)
+214ms ║╔Execution stage started
+215ms ║╚Execution stage complete. (2ms)
+217ms ╚Event processed successfully (218ms)
23/01/2019, 08:58:21 +82ms
+1ms ╔Received event [Bathroom Spot 1].switch = on with a delay of 319ms
+9491ms ║RunTime Analysis CS > 19ms > PS > 9412ms > PE > 59ms > CE
+9492ms ║Piston waited at a semaphore for 9341ms
+9495ms ║Runtime (45635 bytes) successfully initialized in 9412ms (v0.3.109.20181207) (9492ms)
+9496ms ║╔Execution stage started
+9515ms ║║Condition #5 evaluated false (13ms)
+9517ms ║║Condition group #1 evaluated false (state did not change) (15ms)
+9529ms ║║Comparison (enum) active stays (string) inactive = false (2ms)
+9532ms ║║Cancelling any timed trigger schedules for condition 12
+9533ms ║║Cancelling statement #12’s schedules…
+9534ms ║║Condition #12 evaluated false (14ms)
+9535ms ║║Condition group #8 evaluated false (state did not change) (15ms)
+9555ms ║║Comparison (enum) on changes_to (string) on = false (1ms)
+9558ms ║║Cancelling condition #18’s schedules…
+9559ms ║║Condition #18 evaluated false (20ms)
+9561ms ║║Cancelling condition #14’s schedules…
+9562ms ║║Condition group #14 evaluated false (state changed) (24ms)
+9579ms ║║Comparison (enum) on changes_to (string) off = false (0ms)
+9582ms ║║Condition #26 evaluated false (16ms)
+9583ms ║║Condition group #23 evaluated false (state did not change) (18ms)
+9585ms ║╚Execution stage complete. (90ms)
+9587ms ╚Event processed successfully (9587ms)
23/01/2019, 08:58:21 +162ms
+1ms ╔Received event [Bathroom Spot 4].switch = on with a delay of 307ms
+154ms ║RunTime Analysis CS > 19ms > PS > 56ms > PE > 78ms > CE
+157ms ║Runtime (45572 bytes) successfully initialized in 56ms (v0.3.109.20181207) (154ms)
+158ms ║╔Execution stage started
+172ms ║║Condition #5 evaluated false (8ms)
+174ms ║║Condition group #1 evaluated false (state did not change) (9ms)
+195ms ║║Comparison (enum) active stays (string) inactive = false (2ms)
+198ms ║║Cancelling any timed trigger schedules for condition 12
+199ms ║║Cancelling statement #12’s schedules…
+200ms ║║Condition #12 evaluated false (16ms)
+201ms ║║Condition group #8 evaluated false (state did not change) (17ms)
+222ms ║║Comparison (enum) on changes_to (string) on = true (1ms)
+225ms ║║Cancelling condition #18’s schedules…
+226ms ║║Condition #18 evaluated true (21ms)
+228ms ║║Cancelling condition #14’s schedules…
+229ms ║║Condition group #14 evaluated true (state changed) (24ms)
+240ms ║║Comparison (boolean) true is (boolean) true = true (2ms)
+242ms ║║Cancelling condition #30’s schedules…
+243ms ║║Condition #30 evaluated true (11ms)
+245ms ║║Cancelling condition #27’s schedules…
+246ms ║║Condition group #27 evaluated true (state changed) (14ms)
+249ms ║║Cancelling statement #28’s schedules…
+256ms ║║Executed virtual command setVariable (3ms)
+275ms ║║Comparison (enum) on changes_to (string) off = false (1ms)
+278ms ║║Cancelling condition #26’s schedules…
+279ms ║║Condition #26 evaluated false (18ms)
+281ms ║║Cancelling condition #23’s schedules…
+282ms ║║Condition group #23 evaluated false (state changed) (22ms)
+285ms ║╚Execution stage complete. (128ms)
+289ms ╚Event processed successfully (287ms)
23/01/2019, 08:58:20 +297ms
+1ms ╔Received event [Bathroom Sensor].motion = active with a delay of 146ms
+112ms ║RunTime Analysis CS > 17ms > PS > 38ms > PE > 58ms > CE
+115ms ║Runtime (45577 bytes) successfully initialized in 38ms (v0.3.109.20181207) (113ms)
+116ms ║╔Execution stage started
+126ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+128ms ║║Cancelling condition #5’s schedules…
+129ms ║║Condition #5 evaluated true (7ms)
+521ms ║║Comparison (enum) off is (string) off = true (2ms)
+524ms ║║Cancelling condition #6’s schedules…
+525ms ║║Condition #6 evaluated true (395ms)
+531ms ║║Comparison (string) :ccf413a3d2ef9ed766007dcbb2d3408d: is_not (string) :85be758d258a40390d4eeb1504b3b5c4: = true (3ms)
+533ms ║║Condition #39 evaluated true (6ms)
+534ms ║║Cancelling condition #1’s schedules…
+535ms ║║Condition group #1 evaluated true (state changed) (414ms)
+538ms ║║Cancelling statement #2’s schedules…
+550ms ║║Executed virtual command [Bathroom Spot 1, Bathroom Spot 2, Bathroom Spot 3, Bathroom Spot 4].setVariable (6ms)
+576ms ║║Executed physical command [Bathroom Spot 1].setLevel([100]) (21ms)
+577ms ║║Executed [Bathroom Spot 1].setLevel (24ms)
+597ms ║║Executed physical command [Bathroom Spot 2].setLevel([100]) (18ms)
+598ms ║║Executed [Bathroom Spot 2].setLevel (20ms)
+619ms ║║Executed physical command [Bathroom Spot 3].setLevel([100]) (18ms)
+620ms ║║Executed [Bathroom Spot 3].setLevel (20ms)
+641ms ║║Executed physical command [Bathroom Spot 4].setLevel([100]) (20ms)
+643ms ║║Executed [Bathroom Spot 4].setLevel (21ms)
+644ms ║║Skipping task 35 because of mode restrictions
+645ms ║║Skipping task 37 because of mode restrictions
+663ms ║║Executed physical command [Bathroom Spot 1].setColorTemperature([6410]) (14ms)
+665ms ║║Executed [Bathroom Spot 1].setColorTemperature (15ms)
+680ms ║║Executed physical command [Bathroom Spot 2].setColorTemperature([6410]) (14ms)
+681ms ║║Executed [Bathroom Spot 2].setColorTemperature (15ms)
+696ms ║║Executed physical command [Bathroom Spot 3].setColorTemperature([6410]) (13ms)
+697ms ║║Executed [Bathroom Spot 3].setColorTemperature (15ms)
+712ms ║║Executed physical command [Bathroom Spot 4].setColorTemperature([6410]) (13ms)
+713ms ║║Executed [Bathroom Spot 4].setColorTemperature (15ms)
+715ms ║║Skipping task 36 because of mode restrictions
+721ms ║║Skipped execution of physical command [Bathroom Spot 1].on([]) because it would make no change to the device. (3ms)
+722ms ║║Executed [Bathroom Spot 1].on (5ms)
+741ms ║║Executed physical command [Bathroom Spot 2].on() (17ms)
+742ms ║║Executed [Bathroom Spot 2].on (19ms)
+761ms ║║Executed physical command [Bathroom Spot 3].on() (17ms)
+762ms ║║Executed [Bathroom Spot 3].on (19ms)
+781ms ║║Executed physical command [Bathroom Spot 4].on() (17ms)
+783ms ║║Executed [Bathroom Spot 4].on (19ms)
+793ms ║║Comparison (enum) active stays (string) inactive = false (2ms)
+795ms ║║Cancelling any timed trigger schedules for condition 12
+796ms ║║Cancelling statement #12’s schedules…
+797ms ║║Condition #12 evaluated false (11ms)
+799ms ║║Condition group #8 evaluated false (state did not change) (12ms)
+820ms ║║Condition #18 evaluated false (18ms)
+821ms ║║Condition group #14 evaluated false (state did not change) (20ms)
+842ms ║║Cancelling condition #26’s schedules…
+843ms ║║Condition #26 evaluated false (18ms)
+845ms ║║Cancelling condition #23’s schedules…
+846ms ║║Condition group #23 evaluated false (state changed) (22ms)
+849ms ║╚Execution stage complete. (733ms)
+851ms ╚Event processed successfully (851ms)
