Iâm not getting consistent results here, so maybe for my setup I need to modify it a bit? Iâll post a snapshot of my pistonâŚItâs not activating the light based on motion unless I change the 'if" for motion sensing activate as never cancelâŚotherwise, it doesnât seem to work (I modified it back to the original piston without this in the below screenshot.) I tried to override the motion by having no motion, then turning on the physical switch, which seemed to work as long as I waited (around 6 seconds) for ST to show the switch on, then motion didnât seem to matter (which is what I want.) However, once in this mode, even when I turned the physical switch off, motion will subsequently turn the light on, but after 10 seconds, the light wonât go back offâŚlol! Help
