My piston is designed to turn on the AC and the light when I come into the room. That works well. They keep turning off while I am in the room
When a virtual switch is off, the AC and light turn on when I walk into the room. Then, after the sensor doesn’t see motion for 15 minutes, all of the connected devices in the room (fan, lights, AC) will turn off. The virtual switch is there so I can disable the piston by telling Alexa to turn on the virtual switch.
Everything turns on as expected when I walk in the room. Everything keeps turning off even though I am moving about regularly. My desk is against the wall, I am facing the wall, and the sensor is right above the monitors. A turn of my head from monitor to monitor is enough to trigger the sensor.
8/4/2020, 11:26:52 PM +191ms
+1ms ╔Received event [Frog Motion Sensor].motion = active with a delay of 75ms
+89ms ║RunTime Analysis CS > 23ms > PS > 5ms > PE > 61ms > CE
+91ms ║Runtime (38053 bytes) successfully initialized in 5ms (v0.3.110.20191009) (89ms)
+102ms ║║Comparison (enum) off is (string) off = true (1ms)
+104ms ║║Condition #1 evaluated true (7ms)
+104ms ║║Condition group #null evaluated true (state did not change) (9ms)
+109ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+111ms ║║Cancelling condition #3's schedules...
+113ms ║║Cancelling statement #4's schedules...
+119ms ║║Skipped execution of physical command [Frog AC].on([]) because it would make no change to the device. (2ms)
+120ms ║║Executed [Frog AC].on (4ms)
+134ms ║║Skipped execution of physical command [Office Light].on([]) because it would make no change to the device. (9ms)
+135ms ║║Executed [Office Light].on (11ms)
+136ms ║║Condition #3 evaluated true (30ms)
+137ms ║║Cancelling condition #2's schedules...
+138ms ║║Condition group #2 evaluated true (state changed) (32ms)
+140ms ║╚Execution stage complete. (48ms)
+142ms ║Setting up scheduled job for Tue, Aug 4 2020 @ 11:45:49 PM EDT (in 1136.796s)
+154ms ╚Event processed successfully (154ms)
8/4/2020, 11:23:36 PM +944ms
+1ms ╔Received event [Frog Motion Sensor].motion = inactive with a delay of 72ms
+78ms ║RunTime Analysis CS > 21ms > PS > 6ms > PE > 50ms > CE
+80ms ║Runtime (38048 bytes) successfully initialized in 6ms (v0.3.110.20191009) (78ms)
+89ms ║║Comparison (enum) off is (string) off = true (1ms)
+90ms ║║Condition #1 evaluated true (7ms)
+91ms ║║Condition group #null evaluated true (state did not change) (8ms)
+95ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+96ms ║║Cancelling condition #3's schedules...
+97ms ║║Condition #3 evaluated false (4ms)
+98ms ║║Cancelling condition #2's schedules...
+99ms ║║Condition group #2 evaluated false (state changed) (7ms)
+103ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+105ms ║║Condition #7 evaluated false (5ms)
+106ms ║║Condition group #6 evaluated false (state did not change) (6ms)
+108ms ║╚Execution stage complete. (28ms)
+109ms ║Setting up scheduled job for Tue, Aug 4 2020 @ 11:45:49 PM EDT (in 1332.075s)
+144ms ╚Event processed successfully (144ms)
8/4/2020, 11:22:24 PM +740ms
+1ms ╔Received event [Frog Motion Sensor].motion = active with a delay of 55ms
+68ms ║RunTime Analysis CS > 19ms > PS > 4ms > PE > 45ms > CE
+71ms ║Runtime (38053 bytes) successfully initialized in 4ms (v0.3.110.20191009) (68ms)
+71ms ║╔Execution stage started
+79ms ║║Comparison (enum) off is (string) off = true (1ms)
+81ms ║║Condition #1 evaluated true (7ms)
+81ms ║║Condition group #null evaluated true (state did not change) (7ms)
+86ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+87ms ║║Cancelling condition #3's schedules...
+89ms ║║Cancelling statement #4's schedules...
+95ms ║║Skipped execution of physical command [Frog AC].on([]) because it would make no change to the device. (3ms)
+96ms ║║Executed [Frog AC].on (4ms)
+104ms ║║Skipped execution of physical command [Office Light].on([]) because it would make no change to the device. (5ms)
+104ms ║║Executed [Office Light].on (6ms)
+106ms ║║Condition #3 evaluated true (22ms)
+107ms ║║Cancelling condition #2's schedules...
+107ms ║║Condition group #2 evaluated true (state changed) (24ms)
+109ms ║╚Execution stage complete. (38ms)
+111ms ║Setting up scheduled job for Tue, Aug 4 2020 @ 11:45:49 PM EDT (in 1404.278s)
+131ms ╚Event processed successfully (130ms)
8/4/2020, 11:22:09 PM +531ms
+1ms ╔Received event [Frog Motion Sensor].motion = inactive with a delay of 67ms
+70ms ║RunTime Analysis CS > 17ms > PS > 5ms > PE > 47ms > CE
+72ms ║Runtime (38048 bytes) successfully initialized in 5ms (v0.3.110.20191009) (70ms)
+81ms ║║Comparison (enum) off is (string) off = true (1ms)
+82ms ║║Condition #1 evaluated true (6ms)
+83ms ║║Condition group #null evaluated true (state did not change) (8ms)
+88ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+89ms ║║Cancelling condition #3's schedules...
+90ms ║║Condition #3 evaluated false (5ms)
+91ms ║║Cancelling condition #2's schedules...
+92ms ║║Condition group #2 evaluated false (state changed) (7ms)
+97ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+99ms ║║Condition #7 evaluated false (6ms)
+100ms ║║Condition group #6 evaluated false (state did not change) (7ms)
+103ms ║╚Execution stage complete. (29ms)
+104ms ║Setting up scheduled job for Tue, Aug 4 2020 @ 11:45:49 PM EDT (in 1419.494s)
+115ms ╚Event processed successfully (115ms)
8/4/2020, 11:20:37 PM +225ms
+2ms ╔Received event [Frog Motion Sensor].motion = active with a delay of 73ms
+74ms ║RunTime Analysis CS > 21ms > PS > 4ms > PE > 48ms > CE
+76ms ║Runtime (38053 bytes) successfully initialized in 4ms (v0.3.110.20191009) (74ms)
+77ms ║╔Execution stage started
+86ms ║║Comparison (enum) off is (string) off = true (1ms)
+88ms ║║Condition #1 evaluated true (8ms)
+89ms ║║Condition group #null evaluated true (state did not change) (8ms)
+94ms ║║Comparison (enum) active changes_to (string) active = true (0ms)
+95ms ║║Cancelling condition #3's schedules...
+97ms ║║Cancelling statement #4's schedules...
+104ms ║║Skipped execution of physical command [Frog AC].on([]) because it would make no change to the device. (3ms)
+105ms ║║Executed [Frog AC].on (5ms)
+117ms ║║Skipped execution of physical command [Office Light].on([]) because it would make no change to the device. (8ms)
+118ms ║║Executed [Office Light].on (9ms)
+119ms ║║Condition #3 evaluated true (28ms)
+120ms ║║Cancelling condition #2's schedules...
+121ms ║║Condition group #2 evaluated true (state changed) (31ms)
+123ms ║╚Execution stage complete. (46ms)
+125ms ║Setting up scheduled job for Tue, Aug 4 2020 @ 11:45:49 PM EDT (in 1511.779s)
8/4/2020, 11:20:00 PM +131ms
+1ms ╔Received event [Frog Motion Sensor].motion = inactive with a delay of 74ms
+82ms ║RunTime Analysis CS > 21ms > PS > 5ms > PE > 56ms > CE
+84ms ║Runtime (38048 bytes) successfully initialized in 5ms (v0.3.110.20191009) (82ms)
+93ms ║║Comparison (enum) off is (string) off = true (1ms)
+94ms ║║Condition #1 evaluated true (6ms)
+95ms ║║Condition group #null evaluated true (state did not change) (7ms)
+100ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+101ms ║║Cancelling condition #3's schedules...
+102ms ║║Condition #3 evaluated false (4ms)
+103ms ║║Cancelling condition #2's schedules...
+103ms ║║Condition group #2 evaluated false (state changed) (6ms)
+108ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+110ms ║║Condition #7 evaluated false (6ms)
+111ms ║║Condition group #6 evaluated false (state did not change) (7ms)
+113ms ║╚Execution stage complete. (28ms)
+114ms ║Setting up scheduled job for Tue, Aug 4 2020 @ 11:45:49 PM EDT (in 1548.883s)
+129ms ╚Event processed successfully (129ms)
8/4/2020, 11:18:58 PM +90ms
+1ms ╔Received event [Frog Motion Sensor].motion = active with a delay of 71ms
+73ms ║RunTime Analysis CS > 21ms > PS > 4ms > PE > 48ms > CE
+75ms ║Runtime (38053 bytes) successfully initialized in 4ms (v0.3.110.20191009) (73ms)
+76ms ║╔Execution stage started
+84ms ║║Comparison (enum) off is (string) off = true (1ms)
+85ms ║║Condition #1 evaluated true (7ms)
+86ms ║║Condition group #null evaluated true (state did not change) (8ms)
+91ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+92ms ║║Cancelling condition #3's schedules...
+94ms ║║Cancelling statement #4's schedules...
+101ms ║║Skipped execution of physical command [Frog AC].on([]) because it would make no change to the device. (3ms)
+102ms ║║Executed [Frog AC].on (4ms)
+114ms ║║Skipped execution of physical command [Office Light].on([]) because it would make no change to the device. (7ms)
+114ms ║║Executed [Office Light].on (9ms)
+116ms ║║Condition #3 evaluated true (28ms)
+117ms ║║Cancelling condition #2's schedules...
+118ms ║║Condition group #2 evaluated true (state changed) (29ms)
+120ms ║╚Execution stage complete. (45ms)
+121ms ║Setting up scheduled job for Tue, Aug 4 2020 @ 11:45:49 PM EDT (in 1610.918s)
+133ms ╚Event processed successfully (133ms)
8/4/2020, 11:18:53 PM +759ms
+2ms ╔Received event [Frog Motion Sensor].motion = inactive with a delay of 80ms
+80ms ║RunTime Analysis CS > 23ms > PS > 6ms > PE > 50ms > CE
+82ms ║Runtime (38048 bytes) successfully initialized in 6ms (v0.3.110.20191009) (80ms)
+92ms ║║Comparison (enum) off is (string) off = true (1ms)
+94ms ║║Condition #1 evaluated true (9ms)
+95ms ║║Condition group #null evaluated true (state did not change) (9ms)
+99ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+100ms ║║Cancelling condition #3's schedules...
+101ms ║║Condition #3 evaluated false (4ms)
+102ms ║║Cancelling condition #2's schedules...
+103ms ║║Condition group #2 evaluated false (state changed) (7ms)
+108ms ║║Comparison (enum) inactive stays (string) inactive = true (2ms)
+110ms ║║Condition #7 evaluated false (5ms)
+111ms ║║Condition group #6 evaluated false (state did not change) (6ms)
+113ms ║╚Execution stage complete. (31ms)
+114ms ║Setting up scheduled job for Tue, Aug 4 2020 @ 11:45:49 PM EDT (in 1615.255s)
+126ms ╚Event processed successfully (126ms)
8/4/2020, 11:15:56 PM +900ms
+1ms ╔Received event [Frog Motion Sensor].motion = active with a delay of 116ms
+68ms ║RunTime Analysis CS > 17ms > PS > 5ms > PE > 46ms > CE
+70ms ║Runtime (38054 bytes) successfully initialized in 5ms (v0.3.110.20191009) (68ms)
+80ms ║║Comparison (enum) off is (string) off = true (1ms)
+81ms ║║Condition #1 evaluated true (8ms)
+82ms ║║Condition group #null evaluated true (state did not change) (8ms)
+239ms ║║Executed physical command [Frog AC].on() (146ms)
+240ms ║║Executed [Frog AC].on (148ms)
+252ms ║║Skipped execution of physical command [Office Light].on([]) because it would make no change to the device. (8ms)
+253ms ║║Executed [Office Light].on (10ms)
+254ms ║║Condition #3 evaluated true (171ms)
+255ms ║║Cancelling condition #2's schedules...
+256ms ║║Condition group #2 evaluated true (state changed) (173ms)
+258ms ║╚Execution stage complete. (188ms)
+259ms ║Setting up scheduled job for Tue, Aug 4 2020 @ 11:45:49 PM EDT (in 1791.969s)
+267ms ╚Event processed successfully (267ms)
8/4/2020, 11:15:48 PM +992ms
+1ms ╔Received event [Frog Motion Sensor].motion = inactive with a delay of 86ms
+106ms ║RunTime Analysis CS > 22ms > PS > 6ms > PE > 79ms > CE
+109ms ║Runtime (38054 bytes) successfully initialized in 6ms (v0.3.110.20191009) (107ms)
+110ms ║╔Execution stage started
+120ms ║║Comparison (enum) off is (string) off = true (1ms)
+121ms ║║Condition #1 evaluated true (8ms)
+122ms ║║Condition group #null evaluated true (state did not change) (9ms)
+126ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+128ms ║║Condition #3 evaluated false (4ms)
+129ms ║║Condition group #2 evaluated false (state did not change) (5ms)
+133ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+135ms ║║Adding a timed trigger schedule for condition 7
+137ms ║║Condition #7 evaluated false (7ms)
+138ms ║║Condition group #6 evaluated false (state did not change) (9ms)
+140ms ║╚Execution stage complete. (30ms)
+141ms ║Setting up scheduled job for Tue, Aug 4 2020 @ 11:45:49 PM EDT (in 1799.995s)
+155ms ╚Event processed successfully (155ms)
8/4/2020, 11:15:14 PM +634ms
+1ms ╔Starting piston... (v0.3.110.20191009)
+424ms ║╔Subscribing to devices...
+462ms ║║Subscribing to Frog Motion Sensor.motion...
+520ms ║║Subscribing to Sleep Over...
+522ms ║║Subscribing to Frog AC...
+523ms ║║Subscribing to Frog Fan...
+524ms ║║Subscribing to Frog Fan Light1...
+525ms ║║Subscribing to Frog Fan Light2...
+526ms ║║Subscribing to Frog Lamp...
+527ms ║║Subscribing to Office Light...
+528ms ║╚Finished subscribing (111ms)
+550ms ║Comparison (enum) off is (string) off = true (2ms)
+559ms ║Cancelling condition #3's schedules...
+565ms ║Cancelling condition #2's schedules...
+574ms ║Comparison (enum) active stays (string) inactive = false (2ms)
+576ms ║Cancelling condition #7's schedules...
+577ms ║Cancelling condition #6's schedules...
+589ms ╚Piston successfully started (588ms)
