I set the lights to turn off when motion sensor’s motion stays inactive for 10 minutes. But when the timer starts it does not reset to 10 minutes if additional motion is detected.
Timer resets whenever motion is detected
When piston detects motion is inactive it turns off the lights in 10 minutes even if there is more motion in between
2/15/2020, 1:16:10 PM +506ms
+2ms ╔Received event [Motion Sensor - Kitchen].motion = active with a delay of 147ms
+59ms ║RunTime Analysis CS > 20ms > PS > 26ms > PE > 13ms > CE
+61ms ║Runtime (36943 bytes) successfully initialized in 26ms (v0.3.110.20191009) (59ms)
+62ms ║╔Execution stage started
+69ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+71ms ║║Cancelling condition #2's schedules...
+71ms ║║Condition #2 evaluated true (5ms)
+72ms ║║Cancelling condition #1's schedules...
+73ms ║║Condition group #1 evaluated true (state changed) (7ms)
+75ms ║║Cancelling statement #7's schedules...
+94ms ║║Executed physical command [Lights - Kitchen].on() (13ms)
+95ms ║║Executed [Lights - Kitchen].on (15ms)
+97ms ║╚Execution stage complete. (35ms)
+99ms ║Setting up scheduled job for Sat, Feb 15 2020 @ 1:25:10 PM EST (in 540.033s)
+126ms ╚Event processed successfully (126ms)
