Never setup a piston before. I’d like my motion sensor to turn on a master bulb with motion and off when motion stops. This would be 15mins before sundown and 15mins after sunrise… I’d like to keep the lights on if manually turned on via Alexa and then stay on until manually turned off via Alexa. I have set up a virtual switch via IFTTT that turns on/off when Alexa turns on/off the bulb I’d like to control and was hoping to use that virtual switch to override the motion sensor controls
(PUT YOUR INFO HERE)
(UPLOAD YOUR IMAGE HERE)
