Piston doesn’t always fire
when motion, start a counter and if counter hits 1 then turn on lights,
piston very inconsistent the reason for the counter is I don’t want motion to keep firing the piston while the room is occupied so I wanted to restrict it to only running once while in a room, I also tried this with boolean and had same results. It seems to work ok with when I set it when motion counter = 1 but it still runs piston, I had it working before when motion counter changes to 1 but that’s where it starts getting inconsistent for some reason. any help is appreciated
