The piston below works fine. I apologize for what may be a silly question, but I cannot find how to do this. I’m looking for a way to do a multi-line/column array (not sure I’m asking that correctly). I’m not even sure that WC allows multi-line arrays.
I’d like to set up a multi-line/column array so that I don’t have to have each mode change ‘block’ in the piston set the variable the way I’m currently doing it. In the define section, I’d like to set a Dynamic List something like this:
ArrayList[0] = “Away”; {@AwayHeatSP}; {@AwayCoolSP}
ArrayList[1] = “Vacation”; {@VacHeatSP}; {@VacCoolSP}
ArrayList[2] = “Home”; {@HomeHeatSP}; {@HomeCoolSP}
Then, In each Mode Change Block, I could just set the index number and then in the Change and Confirm Block, address the proper array elements to set and confirm the location mode and thermostat’s setpoints - ArrayIndex{index#],1, etc…
Again, the piston works as is. Just trying to use a multi-line/column array.
Not needed for this discussion.
None of that may be clear, so ask away if needed. Thanks!
Lee
