I have a xaiomi aqara single button paired in ST with bsprangers DTH. I would like to create a piston that can turn lights on at 100% brightness with a single press and various dimmed levels with a double, triple and quadruple press. The problem I have is getting the off function correct. When the lights are dimmed using double, triple or quadruple push and I try to toggle them off, they will go to 100% first and I have to press the button agin to toggle off.
The button functions a double press as button 2 of the device, and triple as button 3 and so on.
When button is pressed once, lights on 100%.
When button is pressed twice, lights on 75%
When button is pressed three times, lights on 50%
When button is pressed four times, lights on 25%
When button is toggled once, lights off.
I can get lights to toggle on and off, but not in combination with off at the correct stage.
