I am trying to use a CASE statement with multiple devices. This is probably easy, but I just cannot get the syntax correct. I am using Echo Speaks and the wasLastSpokenToDevice attribute. I have a CASE statement that works. But how do I use multiple devices in a single CASE statement? Currently I am duplicating the CASE statement with each individual Echo device. Can I list multiple devices and not duplicate so much code?
Multiple devices in CASE statement
Pantheon
elf
I would just change the SWITCH statement’s Case Traversal Policy (see its Options) to “Fall-through”, then edit the SWITCH-CASE block, e.g.:
switch({LastEcho})
case {@Echo_Great_Room}:
case {@other_room_variable1}:
case {@other_room_variable2}:
with
whatever
do
whatever;
end with;
wait xxx;
with
whatever2
do
whatever2;
end with;
break
case {@Echo_Bathroom}:
case {other_variable3}:
case {other_variableX}:
with
whatever1
do
whatever1;
end with;
wait xxxxx;
with
whatever3
do
whatever3;
end with;
break
end switch;
