Multiple time values in a variable
Is is possible to have multiple time values in a variable? I want to set a variable to trigger a switch to water my garden twice per day and then have it send a notification when this is done. I could probably do this with an “or” statement and a second variable, but I’m wondering if it is possible to have multiple times in a single variable the way that you can have multiple devices in a single variable.
here is the piston I’m working on. It currently only waters once per day, but I’d like to ultimately have it go off in the evening too.
thanks
I’d like to bump this topic to create a timer statement along the lines of:
every day at <HH:mm, HH:mm and HH:mm>
do
whatever
end every
Instead like the poster above pointed out, it seems one is limited to doing something like this:
ifif
Perhaps I’m overlooking the obvious, yet my question is; is there a better way to do this? Thanks.
I am working on exactly this. Did you find a better way?
// this was just answered here
