I have a push button and 4 lamps. For each push I want to turn on a lamp.
push 1: Turn on lamp 1
push 2: thurn on lamp 1 2
push 3: turn on lamp 1 2 3
push 4: lamp 1 2 3 4
push 5: turn OFF lamp 1 2 3 4
template: 9tg4 see below
not sure how to do it. Tried with case and adding 1 to a variable. not sure if the expression is correct as it doesnt seem to add 1 to the variable.
variable stays 0 , lamps dont do anything
1/13/2020, 7:02:26 PM +569ms
+2ms ╔Received event [IKEA TRÅDFRI Remote].button = pushed with a delay of 91ms
+85ms ║RunTime Analysis CS > 18ms > PS > 53ms > PE > 14ms > CE
+88ms ║Runtime (40285 bytes) successfully initialized in 53ms (v0.3.110.20191009) (86ms)
+99ms ║║Comparison (enum) pushed gets (string) pushed = true (4ms)
+101ms ║║Condition #2 evaluated true (7ms)
+102ms ║║Condition group #1 evaluated true (state did not change) (9ms)
+104ms ║║Cancelling statement #3’s schedules…
+110ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+113ms ║║Executed virtual command setVariable (1ms)
+131ms ║║Executed virtual command sendPushNotification (15ms)
+135ms ║║Evaluating switch with values [[i:6:null:0, v:[t:integer, v:1, vt:string]]]
+138ms ║║Comparison (integer) 1 is (integer) 1 = true (1ms)
+140ms ║║Cancelling statement #12’s schedules…
+147ms ║║Skipped execution of physical command [LB LIR BR30 RGB SY09].on([]) because it would make no change to the device. (2ms)
+148ms ║║Executed [LB LIR BR30 RGB SY09].on (4ms)
+150ms ║╚Execution stage complete. (61ms)
