Mutiple Devices but turn off only the one that triggers piston
I have the following piston in the screenshot attached. It basically is triggered if any of my siren’s are on and then it waits 5 minutes and then turns off both sirens and then sends a push notification saying Siren turned off. However, I wanted to know is there a way to only turn off the one that has triggered the piston and also put which siren was turned off in the push notification?
You want the $currentEventDevice variable.
