My night mode is not triggered based on a virtual switch i have setup. For some reason webcore is declaring a flase even though the virtual switch has changed state to ON
When a virtual switch turns on indicating that either me or my girlfriend are asleep AND one of us is not in the house AND the location mode is currently not set to Away or Vacation mode THEN the night mode is suppose to trigger. In a usual scenario we each have our own button that says when we are going to bed. If one of us clicks that bottom before the other it means that one of us is going to be first maybe becuase i am watching TV downstairs what happens then is usually the mode switches to Someone Asleep mode and turns off the bedroom lights and sets the thermostat in that zone to a certain cooler temp while downstairs where i am usually at it is still normal temp. Now this whole sub flow is suppose to be for the purpose that if I am traveling or if i am not at home and she does the same thing which is turning on her virtual Asleep switch it should then skip the Someone Asleep Mode and go straight to Night mode where it will turn everything off AND turn on the alarm since she is alone at home.
What is not happening is that the piston is not detecting the virtual switch is turning on. I think i will have to separate the two statements into two different statements such as “Miguel’s Asleep switch changes to ON” OR “Amanda’s Asleep switch changes to ON” that seems to be the only one that works but not when they are together
8/15/2018, 9:14:30 PM +977ms
+2ms ╔Received event [Amanda Asleep].switch = on with a delay of 566ms
+164ms ║RunTime Analysis CS > 18ms > PS > 53ms > PE > 93ms > CE
+167ms ║Runtime (43099 bytes) successfully initialized in 53ms (v0.3.107.20180806) (165ms)
+168ms ║╔Execution stage started
+177ms ║║Comparison (string) :b4ba316d4538932c3c6310b325c706fa: is_not_any_of (string) :1923c8c08aa61e0f078115829072ecdb:,:fa43ce3d907291aaba5b16f5e04d00ea: = true (2ms)
+179ms ║║Condition #13 evaluated true (5ms)
+183ms ║║Comparison (string) null executes (string) :425cbfce23c780743c01ab5a5ee6e3c0: = false (2ms)
+184ms ║║Condition #15 evaluated false (4ms)
+194ms ║║Calculating (boolean) true && (boolean) false >> (boolean) false
+197ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+199ms ║║Condition #17 evaluated false (14ms)
+200ms ║║Condition group #20 evaluated false (state did not change) (14ms)
+212ms ║║Comparison (enum) present is (string) not present = false (2ms)
+214ms ║║Comparison (enum) not present is (string) not present = true (1ms)
+215ms ║║Condition #23 evaluated true (14ms)
+222ms ║║Comparison (enum) on changes_to (string) on = false (1ms)
+223ms ║║Condition #24 evaluated false (7ms)
+224ms ║║Condition group #22 evaluated false (state did not change) (24ms)
+225ms ║║Condition group #14 evaluated false (state did not change) (45ms)
+226ms ║║Condition group #1 evaluated false (state did not change) (53ms)
+228ms ║╚Execution stage complete. (60ms)
+229ms ╚Event processed successfully (229ms)
