I have logging set to full and my piston is running every hour but it is not producing any logs. Anyone see this before? Does it have to do with the size of my piston (currently 24 chunks but was also not producing logs at 23 chunks). Anything I can try to get it to produce logs again? At a minimum at full logging it should be showing the event that triggered the run and the execution time. I’m getting nothing.
Piston logs activity
Logs are empty
