I would like to add some sort of a timeout/lockout on the first half of this piston (similar to the one in the 2nd half of the piston), but I’m not quite sure how to structure the logic. The problem I’m having with the piston as it current is, is when one of the presence sensors arrives, then changes to away, and back to arrived in a very short period of time. This ends up setting the house to ‘Home’, then back to ‘Away’, but won’t set it back to ‘Home’ again due to the timeout in the 2nd half of the piston. If there was a timeout in the first half, I think it would solve the issue.
When a presence sensor arrives and then changes to away again rapidly, the portion of the piston that sets the house to ‘away’ wouldn’t run due to a minimum timeout of some sort.
