I’m designing a piston that will switch on the lights for a period of time on motion, and extend that period if there is subsequent motion. However, I want to also allow the lights to be controlled manually to avoid the requirement to keep moving around in the room. As far as that goes, all is fine with the piston below.
The problem occurred when I tried to add code to handle the situation where you trigger the motion, but decide you want manual control and hence not have the lights controlled by motion. My method of initiating this would be to turn off the lights using the switch once you have triggered them with motion, and then back on with the switch, at which point the lights would stay on until switched off by the switch.
I added the ‘if White Bulb 1’s switch changes away from on’ trigger to achieve this.
The lights would go off (due to the switch press) and the control variable would be set to false so that the piston stopped controlling the lights.
The ‘if White Bulb 1’s switch changes away from on’ trigger below is not executed on switch press, until the piston is fired 60 seconds after motion ceases (by the ‘if Motion Sensor 1’s motion stays away from active for 60 seconds’ trigger) - this is when webCoRE has scheduled the next job to run according to the logs. It is behaving as if webCoRE is not subscribing to White Bulb 1’s switch (but there is a lightning bolt in the UI)
24/05/2020, 14:14:47 +474ms
+2ms ╔Received event [Bathroom Lights].switch = off with a delay of 60ms
+125ms ║RunTime Analysis CS > 20ms > PS > 64ms > PE > 40ms > CE
+127ms ║Runtime (43694 bytes) successfully initialized in 64ms (v0.3.10a.20190223) (124ms)
+128ms ║╔Execution stage started
+139ms ║║Condition #2 evaluated false (7ms)
+140ms ║║Condition group #1 evaluated false (state did not change) (8ms)
+145ms ║║Comparison (enum) off changes_away_from (string) on = true (0ms)
+147ms ║║Cancelling condition #45’s schedules…
+148ms ║║Condition #45 evaluated true (4ms)
+149ms ║║Cancelling condition #44’s schedules…
+150ms ║║Condition group #44 evaluated true (state changed) (7ms)
+152ms ║║Cancelling statement #46’s schedules…
+159ms ║║Executed virtual command [Bathroom Lights].setVariable (3ms)
+170ms ║║Comparison (enum) inactive stays_away_from (string) active = true (3ms)
+174ms ║║Adding a timed trigger schedule for condition 38
+176ms ║║Cancelling condition #38’s schedules…
+177ms ║║Condition #38 evaluated false (15ms)
+178ms ║║Cancelling condition #15’s schedules…
+179ms ║║Condition group #15 evaluated false (state changed) (18ms)
+182ms ║╚Execution stage complete. (53ms)
+183ms ║Setting up scheduled job for Sun, May 24 2020 @ 2:15:47 PM BST (in 59.992s)
+191ms ╚Event processed successfully (191ms)
24/05/2020, 14:14:43 +100ms
+1ms ╔Received event [Home].time = 1590326084176 with a delay of -1076ms
+133ms ║RunTime Analysis CS > 19ms > PS > 69ms > PE > 45ms > CE
+136ms ║Runtime (43700 bytes) successfully initialized in 69ms (v0.3.10a.20190223) (135ms)
+159ms ║║Cancelling condition #38’s schedules…
+160ms ║║Condition #38 evaluated true (2ms)
+164ms ║║Comparison (dynamic) true is (boolean) true = true (1ms)
+166ms ║║Cancelling condition #39’s schedules…
+167ms ║║Condition #39 evaluated true (5ms)
+168ms ║║Cancelling condition #15’s schedules…
+169ms ║║Condition group #15 evaluated true (state changed) (10ms)
+171ms ║║Cancelling statement #17’s schedules…
+188ms ║║Executed physical command [Bathroom Lights].off() (13ms)
+189ms ║║Executed [Bathroom Lights].off (15ms)
+194ms ║║Executed virtual command [Bathroom Lights].setVariable (3ms)
+197ms ║╚Execution stage complete. (61ms)
+198ms ╚Event processed successfully (198ms)
24/05/2020, 14:13:44 +21ms
+1ms ╔Received event [Bathroom TriSensor].motion = inactive with a delay of 55ms
+120ms ║RunTime Analysis CS > 21ms > PS > 62ms > PE > 38ms > CE
+122ms ║Runtime (43706 bytes) successfully initialized in 62ms (v0.3.10a.20190223) (120ms)
+123ms ║╔Execution stage started
+130ms ║║Comparison (enum) inactive changes_away_from (string) inactive = false (1ms)
+131ms ║║Condition #2 evaluated false (4ms)
+132ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+143ms ║║Condition #45 evaluated false (8ms)
+144ms ║║Condition group #44 evaluated false (state did not change) (10ms)
+151ms ║║Comparison (enum) inactive stays_away_from (string) active = true (1ms)
+155ms ║║Adding a timed trigger schedule for condition 38
+157ms ║║Condition #38 evaluated false (9ms)
+158ms ║║Condition group #15 evaluated false (state did not change) (11ms)
+159ms ║╚Execution stage complete. (36ms)
+161ms ║Setting up scheduled job for Sun, May 24 2020 @ 2:14:44 PM BST (in 59.995s)
+169ms ╚Event processed successfully (169ms)
24/05/2020, 14:13:42 +582ms
+2ms ╔Received event [Bathroom Lights].switch = on with a delay of 59ms
+119ms ║RunTime Analysis CS > 20ms > PS > 60ms > PE > 39ms > CE
+121ms ║Runtime (43696 bytes) successfully initialized in 60ms (v0.3.10a.20190223) (118ms)
+122ms ║╔Execution stage started
+133ms ║║Cancelling condition #2’s schedules…
+134ms ║║Condition #2 evaluated false (8ms)
+135ms ║║Cancelling condition #1’s schedules…
+136ms ║║Condition group #1 evaluated false (state changed) (10ms)
+141ms ║║Comparison (enum) on changes_away_from (string) on = false (0ms)
+143ms ║║Condition #45 evaluated false (4ms)
+144ms ║║Condition group #44 evaluated false (state did not change) (6ms)
+152ms ║║Comparison (enum) active stays_away_from (string) active = false (1ms)
+153ms ║║Cancelling any timed trigger schedules for condition 38
+154ms ║║Cancelling statement #38’s schedules…
+155ms ║║Condition #38 evaluated false (9ms)
+156ms ║║Condition group #15 evaluated false (state did not change) (10ms)
+158ms ║╚Execution stage complete. (36ms)
+159ms ╚Event processed successfully (159ms)
24/05/2020, 14:13:38 +120ms
+2ms ╔Received event [Bathroom TriSensor].motion = active with a delay of 55ms
+118ms ║RunTime Analysis CS > 20ms > PS > 63ms > PE > 35ms > CE
+120ms ║Runtime (43706 bytes) successfully initialized in 63ms (v0.3.10a.20190223) (117ms)
+128ms ║║Comparison (enum) active changes_away_from (string) inactive = true (0ms)
+129ms ║║Cancelling condition #2’s schedules…
+130ms ║║Condition #2 evaluated true (4ms)
+138ms ║║Comparison (enum) off is (string) off = true (1ms)
+139ms ║║Cancelling condition #10’s schedules…
+140ms ║║Condition #10 evaluated true (9ms)
+148ms ║║Comparison (integer) 1181 is_less_than (integer) 10000 = true (2ms)
+149ms ║║Condition #11 evaluated true (8ms)
+150ms ║║Cancelling condition #9’s schedules…
+151ms ║║Condition group #9 evaluated true (state changed) (20ms)
+152ms ║║Condition group #8 evaluated true (state did not change) (21ms)
+153ms ║║Cancelling condition #1’s schedules…
+154ms ║║Condition group #1 evaluated true (state changed) (28ms)
+156ms ║║Cancelling statement #3’s schedules…
+157ms ║║Skipping task 34 because of mode restrictions
+173ms ║║Executed physical command [Bathroom Lights].setLevel([80]) (14ms)
+174ms ║║Executed [Bathroom Lights].setLevel (15ms)
+184ms ║║Executed physical command [Bathroom Lights].on() (8ms)
+185ms ║║Executed [Bathroom Lights].on (9ms)
+190ms ║║Executed virtual command [Bathroom Lights].setVariable (2ms)
+196ms ║║Cancelling condition #45’s schedules…
+197ms ║║Condition #45 evaluated false (5ms)
+198ms ║║Cancelling condition #44’s schedules…
+199ms ║║Condition group #44 evaluated false (state changed) (7ms)
+205ms ║║Comparison (enum) active stays_away_from (string) active = false (1ms)
+207ms ║║Cancelling any timed trigger schedules for condition 38
+208ms ║║Cancelling statement #38’s schedules…
+208ms ║║Cancelling condition #38’s schedules…
+209ms ║║Condition #38 evaluated false (8ms)
+210ms ║║Condition group #15 evaluated false (state did not change) (9ms)
+212ms ║╚Execution stage complete. (91ms)
+213ms ╚Event processed successfully (213ms)
