But, will changing to (no value set) create the issue of it not running that I ran into before? This was Terminal’s reply:
Need advice on using Echo with motion sensor
WCmore
#47
Your last piston looks good, and you are right… Pressing Test will do nothing. It has to run naturally.
I believe $now is considered “after 120,000”, so this might not be needed, but if your real-life testing fails, you can initialize that variable once by following @Terminal’s example above.
Just make sure to use a time a few minutes in the past.
