Need help updating correct parent and child version
WARNING: Results may be unreliable because the child app’s version (v0.2.101.20171227) is newer than the parent app’s version (v0.2.100.20171211). Please consider updating both apps to the same version.
When you updated did you update all 4 apps? Webcore, webcore piston, webcore dashboard, webcore storage?
yes i updated from repo in the smart things ide. Everything that was in the box and published it
Got it to update finally thanks for the help
What did you end up doing? Incase others run into this issue it helps to post your solution as well.
i updated from repo of all apps and saved than published. Then I went to the main app within the webcore main app and saved and published from there. That was the last step i was missing and worked after that
