If I turn on two rooms the speak command is repeated twice as I have one piston for each room. I would like to combine the two Pistons so that if both rooms are turned on by a routine only one random line of text is spoken. Also if only one room is turned on the text is spoke once which it does now.
When both rooms are turned on the spoken line will only be spoken once Unless only one room or the other is on.
If I turn on both rooms at the same time the random text is spoken twice
