Hi everybody, I’am new to Webcore so I need some help setting up some pistons for my greenhouse
I have a watering pump running 2 minutes every hour… running fine…
What I would like to do is to setup an alarm if the pump does not run.
what i figured was some thing like this:
If wateringpump power rises above 200w
Then start timer at 00:00 (Properly a variable)
If (timer variable) = 02:05
Then Send sms “Pump did not run for 2 hours”
If (timer variable) = 06:05
Then Send sms “Pump did not run for 6 hours”
Should the pump run as scheduled at the next hour the piston should fire and reset the timer back to 00:00
I need help setting up the timer part… Have tried using the time variable with no luck. (setting it to 12:00AM when triggered, hoping i would start counting onward from 12:00)
What is the difference between “Time (time only)” and “Time List (Time only)”
Am I approaching this all wrong?
Thanks in advance
Nicolai
