I have tried Googling, but without success.
Can someone explain to a newbie how to install fuel stream and how to link it to Smartthings and finally how to create a simple piston to send the data.
Any help would be appreciated.
Best wishes.
Best wishes.
Fuel streams are apart of the dashboard for webcore. Here is an example that posts temperature data every 30 minutes
Thank you. I did not realise that the fuel bit was linked to the Dashboard.
I am having problems trying to reproduce your “do” statement.
I click + add new statement
Add an action
This is where I struggle.
Anything I click on means I end up with a “With” if that makes sense and your example does not show a with.
Where do you get "Wholehouse"
Where do you get "House v3…"
What does set piston state do.
Sorry for what may appear to be stupid questions.
Best wishes.
The piston editor cleans up the with location after you save it.
The wholehouse is a variable of all the temp sensors in the house.
House v3 is the canister that I am saving the data into. So it will be grouped together with anything else in that canister.
The piston state is set to display on the piston dashboard page next to the name of the piston
When you go to make a canister, you can’t just make a named canister, it wants me to select a physical or virtual device. I can’t just make a ‘group’ like ‘house v3’… did you make a virtual device called ‘house v3’? I can’t see where to make those either.
