The core premise is simple enough I think - turn on when motion is detected and no other lights are on, wait for 1 minute and turn off. The light turns on as expected based on all the conditions and restrictions in effect. However, it does not turn off after 1 mins.
From the logs I see that it asks for a wake up request after 1 minute. However, when the wakeup request is received, nothing happens.
9/9/2020, 6:53:09 AM +118ms
+0ms â•”Received event [Home].time = 1599655990158 with a delay of -1040ms
+123ms â•‘RunTime Analysis CS > 27ms > PS > 52ms > PE > 44ms > CE
+126ms â•‘Runtime (41724 bytes) successfully initialized in 52ms (v0.3.110.20191009) (125ms)
+127ms â•‘â•”Execution stage started
+128ms ║╚Execution stage complete. (1ms)
+129ms ╚Event processed successfully (129ms)
9/9/2020, 6:52:15 AM +89ms
+1ms â•”Received event [Front Door].contact = closed with a delay of 72ms
+94ms â•‘RunTime Analysis CS > 19ms > PS > 41ms > PE > 34ms > CE
+96ms â•‘Runtime (41727 bytes) successfully initialized in 41ms (v0.3.110.20191009) (94ms)
+97ms â•‘â•”Execution stage started
+137ms â•‘â•‘Comparison (time) 24735189 is_between (time) 1599700680000 .. (time) 1599654960000 = true (8ms)
+138ms â•‘â•‘Time restriction check passed
+140ms â•‘â•‘Condition #1 evaluated true (40ms)
+141ms â•‘â•‘Condition group #null evaluated true (state did not change) (41ms)
+145ms â•‘â•‘Comparison (enum) closed changes_to (string) open = false (0ms)
+147ms â•‘â•‘Cancelling condition #3's schedules...
+147ms â•‘â•‘Condition #3 evaluated false (5ms)
+150ms â•‘â•‘Conditional ladder step failed due to a timeout
+151ms â•‘â•‘Cancelling statement #9's schedules...
+152ms â•‘â•‘Condition group #9 evaluated false (state did not change) (3ms)
+152ms â•‘â•‘Cancelling condition #2's schedules...
+153ms â•‘â•‘Condition group #2 evaluated false (state changed) (11ms)
+155ms ║╚Execution stage complete. (58ms)
+156ms ╚Event processed successfully (156ms)
9/9/2020, 6:52:09 AM +943ms
+1ms â•”Received event [Front Door].contact = open with a delay of 6117ms
+76ms â•‘RunTime Analysis CS > 14ms > PS > 32ms > PE > 30ms > CE
+79ms â•‘Runtime (41734 bytes) successfully initialized in 32ms (v0.3.110.20191009) (77ms)
+80ms â•‘â•”Execution stage started
+114ms â•‘â•‘Comparison (time) 24730026 is_between (time) 1599700680000 .. (time) 1599654960000 = true (8ms)
+115ms â•‘â•‘Time restriction check passed
+117ms â•‘â•‘Condition #1 evaluated true (34ms)
+118ms â•‘â•‘Condition group #null evaluated true (state did not change) (35ms)
+122ms â•‘â•‘Comparison (enum) open changes_to (string) open = true (1ms)
+123ms â•‘â•‘Cancelling condition #3's schedules...
+124ms â•‘â•‘Condition #3 evaluated true (5ms)
+125ms â•‘â•‘Cancelling condition #2's schedules...
+126ms â•‘â•‘Condition group #2 evaluated true (state changed) (7ms)
+160ms â•‘â•‘Comparison (enum) off is (string) off = true (1ms)
+162ms â•‘â•‘Comparison (enum) off is (string) off = true (1ms)
+164ms â•‘â•‘Comparison (enum) off is (string) off = true (1ms)
+167ms â•‘â•‘Comparison (enum) off is (string) off = true (1ms)
+169ms â•‘â•‘Comparison (enum) off is (string) off = true (1ms)
+171ms â•‘â•‘Comparison (enum) off is (string) off = true (1ms)
+173ms â•‘â•‘Condition #13 evaluated true (44ms)
+174ms â•‘â•‘Condition group #12 evaluated true (state did not change) (46ms)
+176ms â•‘â•‘Cancelling statement #4's schedules...
+209ms â•‘â•‘Executed physical command [Passage Light (Hallway)].setLevel([50]) (30ms)
+210ms â•‘â•‘Executed [Passage Light (Hallway)].setLevel (32ms)
+213ms â•‘â•‘Executed virtual command [Passage Light (Hallway)].wait (1ms)
+214ms â•‘â•‘Requesting a wake up for Wed, Sep 9 2020 @ 6:53:10 AM MDT (in 60.0s)
+218ms ║╚Execution stage complete. (139ms)
+220ms â•‘Setting up scheduled job for Wed, Sep 9 2020 @ 6:53:10 AM MDT (in 59.996s)
+228ms ╚Event processed successfully (228ms)
