I pulled an example from here, set up a piston that will send a Push Notification if the plug the washing machine is plugged into raises above 50W to set a Boolean to True. If the Boolean is true and the power dips below 5W for 3 minutes then I get a push Notification.
To get a single Notification when the washing machine is done running.
In the hour and a half since the washing machine finished I’ve gotten four notifications. It has not turned back on and the power did not raise above 50W
