I’ve been playing around with controlling my Daikin One thermostat via REST API. I’ve successfully have tested my REST API calls via POSTMAN but when I try to recreate it in webcore, I can’t seem to send the proper requests. When I make my “web request” actions, I get "Error executing external web request: groovyx.net.http.HttpResponseException: Forbidden"
I should be getting back HTTP status 200 codes with JSON data passed back to me and saved in a variable.
I’m getting forbidden responses back and I am not getting the JSON data I need passed back to me. As mentioned earlier, I can successfully test the API calls in POSTMAN but have not been able to recreate it in webcore successfully. Here is the Daikin One REST API documentation
|+0ms|╔Received event [Home].test = 1651522485236 with a delay of 0ms|
|+44ms|║RunTime Analysis CS > 21ms > PS > 11ms > PE > 13ms > CE|
|+47ms|║Runtime (53591 bytes) successfully initialized in 11ms (v0.3.110.20191009) (46ms)|
|+48ms|║╔Execution stage started|
|+53ms|║║Cancelling statement #1’s schedules…|
|+60ms|║║Calculating (string) URL + (string) /v1/token >> (string) URL|
|+76ms|║║Calculating (string) x-api-key: + (string) 8aty1DYvQ…[TRUNCATED] >> (string) x-api-key: 8aty1DYvQ…[TRUNCATED]|
|+81ms|║║Calculating (string) Content-Type: application/json + (string) , >> (string) Content-Type: application/json,|
|+84ms|║║Calculating (string) Content-Type: application/json, + (string) x-api-key: 8aty1DYvQ…[TRUNCATED] >> (string) Content-Type: application/json, x-api-key: 8aty1DYvQ…[TRUNCATED]|
|+92ms|║║Calculating (string) integratorToken: + (string) eyJjdHkiOiJKV…[TRUNCATED]|
|+96ms|║║Sending external web request to: URL|
|+308ms|║║Error executing external web request: groovyx.net.http.HttpResponseException: Forbidden|
|+310ms|║║Executed virtual command httpRequest (224ms)|
|+316ms|║║Executed virtual command setVariable (3ms)|
|+318ms|║╚Execution stage complete. (270ms)|
|+319ms|╚Event processed successfully (319ms)|
