I just installed a GE DuraStation EVSE Level 2 charger.
When not in use it draws 2w (AC) constanty. That adds up.
I wanted an intelligent switch/relay toturn it on/off.
I know the GE Zwave module is out there. It’s also expensive.
Is there something (relay module) I can control via a Particle Photon/Arduino that’s not going to overheat from long periods of being on with current draw? The unit is a 40a draw unit. So any relay would have to handle that…
I realize the photon will have a draw as well, but it would be negligible in comparison, and I’d also put a light sensor, motion sensor and temp probe on the board as well, so it’d give me some use in the garage while now adding some smartness to the charger.
