Nest Camera Motion Sensor not triggering
motion
I have a very simple piston that I just want to test to see if the nest camera motions get trigger but it doesn’t seem to be, anyone have any idea or maybe it just doesn’t support because the IDE doesn’t support it. TIA
What DTH are you using for your nest camera?
tonesto7 : Nest Camera at least that’s what I’ve published along with other nest DTH.
@sangweb Unfortunately the only way to get reliable motion events is to use the streaming service with NST Manager which will require you to run a service on a linux/raspberry pi
