This is probably a really simple issue but, being new to WebCoRE, I can’t figure it out. I installed Nest Manager, etc., in the IDE. I went through the process to get a Client ID and secret code (sounds like James Bond!). Everything seems to be okay. Nest Manager and NST Automation show up as published in IDE under “My Smartapps.” There are also entries for the devices under “My Devices” and “My Device Handlers.” I was able to set up the Nest Manager on my mobile Smartthings app, which I can now use to control my thermostat. However, Nest does not show up in WebCoRE as a physical device. I’m sure I’m missing something very simple but I have no idea what it is.
I assume that my Nest thermostat should be listed as a physical device in WebCoRE, so that I can use it in pistons.
I see no way to use Nest in WebCoRe pistons.
(UPLOAD YOUR IMAGE HERE)
