I just installed some new fan speed switches. Leviton ZW4SF-1BW Decora Smart z-wave 4 Speed Fan Controller.
Need help switching fan speeds based on room temp. This is a piston I was previously using with virtual switches. I went through and replaced the virtual switches with the actual fans. The piston seems to be changing correctly but it is not actually changing the fan speeds. In ST the apples indicator shows “off, low, medium, high, max”
Fan speeds change based on temp.
Piston is working correctly but fans speeds are not changing.
