New "Vacation" Mode not showing in webCoRE
I created a new “Vacation” mode in the SmartThings Groovy IDE. I have the standard three (Home, Night, Away) plus the new fourth mode (Vacation) showing in the IDE. In the SmartThings Classic app (IOS), I created a new Routine to change to Vacation mode. I can run the Routine, change to Vacation mode, and see I am in Vacation mode in the “More” section.
I do NOT see the new Vacation mode in webCoRE Dashboard. I see Night, Home, and Away. Do I need to somehow manually update webCoRE to see the new mode?
I’ve had thia as well. If I remember correctly it either appeared after a couple of hours or I did a hard reload of my browser page.
Either way it will appear.
Thanks. Right you are…it showed up. Good to know there is such a delay. You can be dead in the water if you are expecting it to show up right away.
If I make any changes to the hub or adding new devices I always refresh my browser page that is running webcore after that. It always has done the trick for me.
