The quick answer:
That drop down lists common commands… but keep in mind that this list is designed to work with many different devices. (IE: they won’t all work on your Qled)
My strategy:
Whenever I get a new device, I usually spend an hour or so with a brand new piston. (using NO triggers) I simply create a one line piston, and experiment with one task/command at a time (by pressing ‘Test’). I take note which ones works on that device, and which ones do not… (then edit piston & change that one line to learn about the next command)
This is (somewhat) to be expected, since ST is trying to connect with hundreds of companies… (and they don’t all program the same way)
