I am using a trigger to initiate a piston but no lightning bolt is showing up as expected
My piston is supposed to turn off my whole house fan once inside temp minus outside temp drops to less than or equal to 4
Webcore states, “This piston does not subscribe to any events. Unless executed by other means, it will never run on its own.” I thought that triggers (not conditions) should initiate a piston. I have used the trigger “drops to or below” so I thought it should have a lightning bolt but does not.
**4) Post a *Green Snapshot
indent preformatted text by 4 spaces
6/9/2022, 9:07:55 AM +230ms
+1ms ╔Starting piston… (v0.3.114.20220203)
+420ms ╚Piston successfully started (420ms)
6/9/2022, 8:58:52 AM +665ms
+646ms ╚Piston successfully started (646ms)
6/9/2022, 8:57:07 AM +733ms
+2ms ╔Starting piston… (v0.3.114.20220203)
+218ms ║Subscribing to Whole house fan.indicatorStatus…
+454ms ╚Piston successfully started (453ms)
6/9/2022, 8:46:41 AM +512ms
+1ms ╔Received event [My home].test = 1654789601509 with a delay of 3ms
+152ms ║Setting up scheduled job for Thu, Jun 9 2022 @ 9:01:41 AM PDT (in 899s)
+159ms ╚Event processed successfully (158ms)
6/8/2022, 9:03:21 AM +107ms
+10ms ╔Received event [My home].time = 1654704181897 with a delay of 19209ms
+990ms ╚Event processed successfully (989ms)
6/8/2022, 8:48:01 AM +789ms
+1ms ╔Received event [My home].test = 1654703281786 with a delay of 3ms
+169ms ║Setting up scheduled job for Wed, Jun 8 2022 @ 9:03:01 AM PDT (in 899s)
+212ms ╚Event processed successfully (212ms)
6/8/2022, 8:47:35 AM +465ms
+505ms ║Subscribing to Whole house fan.indicatorStatus…
+658ms ╚Piston successfully started (657ms)
6/8/2022, 8:44:37 AM +0ms
+0ms ╔Received event [My home].test = 1654703076997 with a delay of 2ms
+113ms ║Setting up scheduled job for Wed, Jun 8 2022 @ 8:59:37 AM PDT (in 899s)
+120ms ╚Event processed successfully (120ms)
6/8/2022, 8:44:04 AM +899ms
+201ms ║Subscribing to Whole house fan.indicatorStatus…
+330ms ╚Piston successfully started (329ms)
5/30/2022, 10:01:04 AM +863ms
+202ms ║Subscribing to Whole house fan.indicatorStatus…
+339ms ╚Piston successfully started (339ms)
5/30/2022, 9:59:00 AM +56ms
+537ms ╚Piston successfully started (537ms)
5/30/2022, 9:58:09 AM +849ms
+543ms ╚Piston successfully started (542ms)
5/30/2022, 9:46:34 AM +523ms
+0ms ╔Received event [My home].test = 1653929194522 with a delay of 0ms
+75ms ╚Event processed successfully (74ms)
