I am trying to get information on the amount of renewables in the power supply grid to start/stop changing of an EV car.
I have a wave switch (not yet installed).
I have found opennem.org.au API which has the data
I am a complete novice at webcore and API interactions. I have reasonable logic skills and a history using VBA Macros so once I get data from the api into webcore I am confident I can manipulate it.
- Use a get statement to return the current grid power makeup
- If required do some calcs to determine % renewables
- Turn on/off switch based on results
I can’t seem to get my head around the syntax required to get the api to return usable data for the WEM grid (I have tried using the web browser to test code). I can get a list of networks, but not any of the data.
I am hoping the data is in the “WEM” network_id https://api.opennem.org.au/stats/fueltech_mix/{network_id}
I have found the developer Documentation at https://developers.opennem.org.au
I am obviously missing something in the syntax or the method - Is anyone able to help getting this information into webcore?
Todd
(UPLOAD YOUR IMAGE HERE)
