(PUT YOUR INFO HERE)
Getting null error without optional piston variable.
| +219ms | ║║Ramjet completed Kitchen K: true B: true L: true G: true |
| +221ms | ║║Executed virtual command log (2ms) |
| +224ms | ║║get Variable ‘null’ not found |
| +226ms | ║║Executed virtual command executePiston (4ms) |
| +228ms | ║╚Execution stage complete. (163ms) |
| +230ms | ╚Event processed successfully (229ms) |
If I put in a variable, there is no error.
Should not display as error if expected behaviour.
First piston is with variable. Behaves correctly. Second piston is without variable. Gives error.
|+219ms|║║Ramjet completed Kitchen K: true B: true L: true G: true|
|+221ms|║║Executed virtual command log (2ms)|
|+224ms|║║**get Variable 'null' not found|**
|+226ms|║║Executed virtual command executePiston (4ms)|
|+228ms|║╚Execution stage complete. (163ms)|
|+230ms|╚Event processed successfully (229ms)|
