State change is not being detected in a piston, but is in another one. I have one piston set up to increase the temperature when in heating mode if either my wife or I come home for lunch. I have another piston that is supposed to unlock the mudroom door if we come home. One triggers, the other does not. Why does only 1 detect the occupancy state change when they execute at the same time?
I am expecting a trigger of the state change of my phone or my wife’s phone to unlock a door. It does not detect the state change. I am also expecting a second piston to detect the state change and change the temperature. That works.
The occupancy state change is not detected in one of the pistons. Both pistons execute at the same time.
Piston not working
Working piston
Log of piston not working
2/16/2021, 11:49:04 AM +938ms
+2ms ╔Received event [SAMSUNG-SM-G950U].occupancy = occupied with a delay of 90ms
+50ms ║RunTime Analysis CS > 20ms > PS > 11ms > PE > 19ms > CE
+52ms ║Runtime (38572 bytes) successfully initialized in 11ms (v0.3.113.20210203) (49ms)
+53ms ║╔Execution stage started
+84ms ║║Comparison (enum) locked is (string) locked = true (2ms)
+85ms ║║Cancelling condition #2’s schedules…
+86ms ║║Condition #2 evaluated true (29ms)
+102ms ║║Comparison (string) occupied changes_to (string) occupied = false (0ms)
+103ms ║║Cancelling condition #3’s schedules…
+104ms ║║Condition #3 evaluated false (17ms)
+105ms ║║Condition group #1 evaluated false (state did not change) (48ms)
+107ms ║╚Execution stage complete. (54ms)
+108ms ╚Event processed successfully (108ms)
Log of piston working
2/16/2021, 11:49:04 AM +925ms
+2ms ╔Received event [SAMSUNG-SM-G950U].occupancy = occupied with a delay of 77ms
+48ms ║RunTime Analysis CS > 23ms > PS > 6ms > PE > 18ms > CE
+51ms ║Runtime (37816 bytes) successfully initialized in 6ms (v0.3.113.20210203) (47ms)
+52ms ║╔Execution stage started
+68ms ║║Comparison (time) 42544983 is_between (time) 30600000 … (time) 57600000 = true (8ms)
+70ms ║║Time restriction check passed
+72ms ║║Condition #2 evaluated true (14ms)
+86ms ║║Comparison (string) occupied changes_to (string) occupied = true (1ms)
+88ms ║║Cancelling condition #3’s schedules…
+89ms ║║Condition #3 evaluated true (17ms)
+90ms ║║Cancelling condition #1’s schedules…
+91ms ║║Condition group #1 evaluated true (state changed) (34ms)
+94ms ║║Cancelling statement #4’s schedules…
+172ms ║║Executed physical command [Thermostat Heat Trigger Button].push1() (74ms)
+174ms ║║Executed [Thermostat Heat Trigger Button].push1 (76ms)
+177ms ║╚Execution stage complete. (126ms)
+178ms ╚Event processed successfully (178ms)
