Routine turns a virtual switch called Goodbye on. That is SUPPOSED to trigger “Goodbye changes to on” and a whole bunch of things are supposed to happen.
The routine does turn Goodbye on but, webcore doesn’t recognize it to run the piston.
I can manually switch it on from the My Home panel and it works fine.
I did change it to Location changes to away but am wondering what could be wrong here. Is it a bug or am I supposed to use conditions instead of triggers if I want to use a routine to switch something on and trigger a piston?
