I want to replace ecobee’s smart away home with this code due to the 2 hour activation time.
when both sensors see unoccupied, I want the ecobee to be in away mode and home when any of two sensors detects motion during certain period.
test result says false all the time when the conditions are met. I am having hard time understanding the difference between trigger and conditions so I want to use only when after evaulating the if statement instead of and. please explain the difference and if I used the time variable correctly. Also,I want to know how to use only when if it can make the piston? more efficient.
10/16/2019, 1:00:19 PM +71ms
+1ms ╔Received event [Home].test = 1571256019071 with a delay of 0ms
+78ms ║RunTime Analysis CS > 21ms > PS > 40ms > PE > 17ms > CE
+81ms ║Runtime (38543 bytes) successfully initialized in 40ms (v0.3.110.20191009) (79ms)
+103ms ║║Comparison (enum) inactive is (string) inactive = true (2ms)
+106ms ║║Comparison (enum) inactive is (string) inactive = true (2ms)
+108ms ║║Condition #2 evaluated true (22ms)
+121ms ║║Comparison (time) 46819181 is_between (time) 28800000 … (time) 64800000 = true (9ms)
+123ms ║║Time restriction check passed
+125ms ║║Condition #14 evaluated true (15ms)
+128ms ║║Cancelling statement #14’s schedules…
+134ms ║║Requesting time schedule wake up at Wed, Oct 16 2019 @ 6:00:00 PM PDT
+140ms ║║Condition group #1 evaluated true (state did not change) (54ms)
+142ms ║║Cancelling statement #5’s schedules…
+146ms ║║Skipping task 6 because of mode restrictions
+158ms ║║Comparison (enum) inactive is (string) active = false (1ms)
+161ms ║║Comparison (enum) inactive is (string) active = false (2ms)
+162ms ║║Condition #10 evaluated false (13ms)
+164ms ║║Condition group #9 evaluated false (state did not change) (16ms)
+193ms ║╚Execution stage complete. (111ms)
+198ms ║Setting up scheduled job for Wed, Oct 16 2019 @ 6:00:00 PM PDT (in 17980.732s), with 1 more job pending
+211ms ╚Event processed successfully (211ms)
10/16/2019, 1:00:05 PM +442ms
+0ms ╔Received event [Home].test = 1571256005438 with a delay of 2ms
+240ms ║Setting up scheduled job for Wed, Oct 16 2019 @ 6:00:00 PM PDT (in 17994.319s), with 1 more job pending
+252ms ╚Event processed successfully (253ms)
