Currently the piston runs if any door is opened,
I would like to execute my “I’m leaving” ST routine and have webCore open the garage (Contact Sensor 6) for me after the laundry room door (Contact Sensor 11) is opened. The piston should only work if the laundry room door (Contact Sensor 11) is opened within 20 seconds of the ST routine “I’m Leaving” executing and should only open the garage if the garage door is in a closed state
Currently the piston runs if any door is opened, I only want it to run when one specific door opens with 20 seconds of the ST routine executing.
