Opening the Door when you arrive home with Intractive Push Notification
I need help on making a peston to send you an intractive push notification when you arrive home to open the door for you, if you press yes botton off push notification then it should open the door
for example if you arrive home the app tells you “you arrived home, Open the the door?” and it should provide tow options/buttons “Yes” and “No” if you push the yes button then the door shoud be opened
I am not sure how the intractive push notification works in Webcore Can someone please help
(UPLOAD YOUR IMAGE HERE)
To my knowledge, push notifications are not interactive by design. However, the basis of what you are attempting has been done via SMS and voice (Alexa/Google).
I recommend you review the posts above as there are a lot of good tips. Quick example is below if you can use SMS:
