I’ve created a webcore graph with local temps and openweather temps. The local data graphs correctly, but the open weather data is limited to what appears to be 12 hours, or maybe a certain number of data points. Where am I going wrong?
OpenWeather data graph limited to 12 hours
E_Sch
If you are using the open weather driver and its attributes, you likely need to enable LTS (Long term storage) for those attributes, otherwise, you duration is limited to the HE database history, which is pretty short.
