Has Openweather changed its API lately?
This is on Hubitat. I have a piston that retrieves info from Openweather every 30 minutes. One of the parts determines the current moon phase. For some reason, I now get this error.
The piston pulls daily.moon_phase info, and determines the label of the moon phase based on the percentage
| +81ms | ║Error retrieving JSON data part moon_phase[0] org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object ‘0.5’ with class ‘java.math.BigDecimal’ to class ‘java.util.Map’ |
| +206ms | ║Error retrieving JSON data part pop[7] org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object ‘0.01’ with class ‘java.math.BigDecimal’ to class ‘java.util.Map’ |
