Need some help with following piston. What should be the command for the bold tasks?
If motion is active
then
- turn on LED strip
2. turn color to daylight
If motion is inactive for 10mins
then
1. turn color of LED strip to ColorLoop
If motion is active
then
turn color to daylight would be “set color” to Preset: Daylight White
Not sure if you can activate colorloop via webcore or not.
In CoRE I use “Turn On” then “Set color temperature to 5500 degrees” Followed by “Set level to 100%”.
I too haven’t seen Colorloop in WebCoRE.
