this should work
since i dont use trendsetter to group lights, you will need to change the with statement on line 28.
this should work
Yep that seems to work, it still starts the countdown when the mode changes to away but if you then turn on a light it restarts once then that’s it so should work well, thanks.
This should now work for you @Hilly_2015 if you set the mode to away or sleep mode it should work for both.
glad it works for you. it doesnt actually restart the countdown, but the UI sort of gives the impression it does.
with the location in right mode. turn on one of the lights and set a timer. then after 10 seconds turn on another light. do the lights turn off at 30 second mark or at 40 second mark of the timer?
