my outdoor lights turns on but does not turn off
outdoor lights should turn on 1 hour after sunset and turns off 1 hour before sunrise
outdoor lights turn on 1 hour after sunset, as designed BUT does not turn off (1 hour before sunrise) as designed.
4/27/2021, 2:27:31 PM +567ms
+1ms ╔Received event [The House].test = 1619548051564 with a delay of 3ms
+59ms ║RunTime Analysis CS > 23ms > PS > 7ms > PE > 29ms > CE
+62ms ║Runtime (38654 bytes) successfully initialized in 7ms (v0.3.113.20210203) (60ms)
+63ms ║╔Execution stage started
+96ms ║║Comparison (time) 52051635 is_before (time) 1619569620000 = true (7ms)
+98ms ║║Time restriction check passed
+100ms ║║Condition #2 evaluated true (31ms)
+104ms ║║Cancelling statement #2’s schedules…
+109ms ║║Requesting time schedule wake up at Tue, Apr 27 2021 @ 9:27:00 PM EDT
+112ms ║║Condition group #1 evaluated true (state did not change) (44ms)
+115ms ║║Cancelling statement #7’s schedules…
+129ms ║║Executed physical command [Back light Left].on() (9ms)
+130ms ║║Executed [Back light Left].on (11ms)
+138ms ║║Skipped execution of physical command [Back light Right].on([]) because it would make no change to the device. (5ms)
+139ms ║║Executed [Back light Right].on (7ms)
+151ms ║║Executed physical command [Front Light Left].on() (9ms)
+153ms ║║Executed [Front Light Left].on (12ms)
+165ms ║║Executed physical command [Front light Right].on() (9ms)
+166ms ║║Executed [Front light Right].on (12ms)
+179ms ║║Executed physical command [Garage light left].on() (10ms)
+180ms ║║Executed [Garage light left].on (12ms)
+192ms ║║Executed physical command [Garage light right].on() (9ms)
+193ms ║║Executed [Garage light right].on (11ms)
+205ms ║║Executed physical command [Side light].on() (9ms)
+206ms ║║Executed [Side light].on (11ms)
+295ms ║║Executed physical command [Back light Left].setLevel([100]) (44ms)
+296ms ║║Executed virtual command [Back light Left].adjustLevel (86ms)
+320ms ║║Executed virtual command [Back light Right].adjustLevel (22ms)
+337ms ║║Executed physical command [Front Light Left].setLevel([100]) (8ms)
+338ms ║║Executed virtual command [Front Light Left].adjustLevel (17ms)
+355ms ║║Executed physical command [Front light Right].setLevel([100]) (7ms)
+356ms ║║Executed virtual command [Front light Right].adjustLevel (17ms)
+375ms ║║Executed physical command [Garage light left].setLevel([100]) (10ms)
+376ms ║║Executed virtual command [Garage light left].adjustLevel (19ms)
+392ms ║║Executed physical command [Garage light right].setLevel([99]) (7ms)
+393ms ║║Executed virtual command [Garage light right].adjustLevel (15ms)
+413ms ║║Executed physical command [Side light].setLevel([100]) (10ms)
+414ms ║║Executed virtual command [Side light].adjustLevel (20ms)
+445ms ║╚Execution stage complete. (382ms)
+448ms ║Setting up scheduled job for Tue, Apr 27 2021 @ 9:27:00 PM EDT (in 25167s), with 1 more job pending
+459ms ╚Event processed successfully (459ms)
