I copied a piston a nice guy provided to have echo speaks tell me when my garage door is open - it tells me after 5 minutes - then reminds me every 5 minutes until I close it. That all works perfectly. What I want to do is ADD an override using a virtual switch called OVERRIDE. So that way if Ii PLAN to leave the door open echo speaks no longer tells me the door is open.
If it turn on OVERRIDE switch (switch24 in this example)- echo speaks won’t tell me the door is open or still open
The over ride works perfectly if I do it BEFORE I open the door… what I want is to turn on the over ride AFTER the door is open and maybe echo speaks has already reminded me once … but I want to stop that now as I am out in the garage and don’t want it talking to the spouse any longer … even though the door will still be open.
I can see my wife getting pissed having Alexa telling her those things…
