Parallelism is the topic/problem, another thing I have been trying to wrap my head around, wish there was a single article detailing how this works. So I am used to Zipato, more than ST, and in Zipato there is a single command called “Join”. Essentially, it means that any time a “Rule” (equivalent of piston) starts running, if it finds other instances of that rule already running (and therefore older ones), it “joins” them to the newer rule. Essentially, what it means is any instances of that rule that it finds already running are killed off.
I can think of various uses for this. The most obvious is turning off the light after a No Motion event is registered. After a No Motionevent, a person may have walked into the room again (essentially some automation/piston fired but did not need to turn the light on as it was already on). That person is still in the room, yet if the initial piston is still running, it will switch off the light after say 3 minutes despite newer Motion events having happened since then. And there are numerous other examples that come to mind - I just wrote a piston to manage my 1st floor heating and I am certain that if 2 instances of the same piston run together, they might create a bit of a mess.
Now one may either not allow parallel running of the same piston and have them lined up to run one after the other, but I believe the most desirable approach is to kill off older instances already running, overriding them with the latest one…
At the moment - nothing is happening, but I realised there was a conflict when multiple instances of the same piston are fired off at exactly the same time… It would be ideal for me to kill off the older instance immediately in the cases I can think of so far) and tun only the last one.
Nothing to paste- just a general question
Nothing to paste.
and I put a refresh in the DTH but it seemed unable to handle multiple refreshes from the same switch). It seems that the DTH was missing some refreshes, or incapable of handling so many refreshes fractions of a second apart, so pressing all buttons on a 4-gang switch in rapid succession still showed only 2 or 3 buttons switched ON on the app. So my intention was to build a piston to get a final refresh at the very end, after all switch buttons are pressed…
