I have a piston that works fine in ST but is completely non-functional in Hubitat and I can’t figure out why. Anyone else have any ideas?
These are the errors I’m getting in Hubitat
[app:149](http://192.168.1.12/logs/past#app149)2018-10-18 11:25:23.363 error ║ An error occurred while executing the event: groovy.lang.StringWriterIOException: java.io.IOException: Stream closed
[app:149](http://192.168.1.12/logs/past#app149)2018-10-18 11:25:23.361 info ║ 000000
[app:149](http://192.168.1.12/logs/past#app149)2018-10-18 11:25:22.275 info ║ [mode:2, ws2812fx_mode:0, ws2812fx_mode_name:Static, speed:192, brightness:96, color:[0, 0, 0]]
[app:149](http://192.168.1.12/logs/past#app149)2018-10-18 11:23:26.451 error ║ An error occurred while executing the event: groovy.lang.StringWriterIOException: java.io.IOException: Stream closed
[app:149](http://192.168.1.12/logs/past#app149)2018-10-18 11:23:26.446 info ║ 000000
[app:149](http://192.168.1.12/logs/past#app149)2018-10-18 11:23:25.351 info ║ [mode:2, ws2812fx_mode:0, ws2812fx_mode_name:Static, speed:192, brightness:96, color:[0, 0, 0]]
[app:149](http://192.168.1.12/logs/past#app149)2018-10-18 11:21:26.950 error ║ An error occurred while executing the event: groovy.lang.StringWriterIOException: java.io.IOException: Stream closed
[app:149](http://192.168.1.12/logs/past#app149)2018-10-18 11:21:26.947 info ║ 000000
[app:149](http://192.168.1.12/logs/past#app149)2018-10-18 11:21:25.869 info ║ [mode:2, ws2812fx_mode:0, ws2812fx_mode_name:Static, speed:192, brightness:96, color:[0, 0, 0]]
[app:149](http://192.168.1.12/logs/past#app149)2018-10-18 11:15:08.192 error ║ An error occurred while executing the event: groovy.lang.StringWriterIOException: java.io.IOException: Stream closed
[app:149](http://192.168.1.12/logs/past#app149)2018-10-18 11:15:08.171 info ║ 000000
[app:149](http://192.168.1.12/logs/past#app149)2018-10-18 11:15:07.016 info ║ [mode:2, ws2812fx_mode:0, ws2812fx_mode_name:Static, speed:196, brightness:100, color:[0, 0, 0]]
