I’m trying to extract the a variable from the post data sent by Emby into my piston via Webhooks. Piston URL has been copied from into WebHook plugin and posts directly to it.
There is no way to filter the outbound URL in Emby so need to parse the post data in order to trigger different actions depending on the event.
There are 4 variables;
playback.pause / unpause / stop / start
Being able to take the variable and use that to trigger different events e.g. turn a light off when unpausing and a light on when pausing.
Unable to parse variable to create bespoke triggers for events.
16/04/2020, 02:12:13 +757ms
+1ms ╔Received event [Home].execute = XX.XXX.203.XXX with a delay of 29ms
+48ms ║RunTime Analysis CS > 12ms > PS > 27ms > PE > 9ms > CE
+50ms ║Runtime (37277 bytes) successfully initialized in 27ms (v0.3.110.20191009) (49ms)
+51ms ║╔Execution stage started
+54ms ║║Cancelling statement #7’s schedules…
+57ms ║║Executed virtual command parseJson (1ms)
+61ms ║║Executed virtual command setVariable (2ms)
+67ms ║║Comparison (string) Event is (string) playback.unpause = false (1ms)
+68ms ║║Condition #11 evaluated false (4ms)
+69ms ║║Condition group #10 evaluated false (state did not change) (6ms)
+71ms ║╚Execution stage complete. (20ms)
+72ms ╚Event processed successfully (71ms)
16/04/2020, 02:12:05 +840ms
+0ms ╔Received event [Home].execute = XX.XXX.203.XXX with a delay of 43ms
+64ms ║RunTime Analysis CS > 16ms > PS > 38ms > PE > 10ms > CE
+66ms ║Runtime (37278 bytes) successfully initialized in 38ms (v0.3.110.20191009) (65ms)
+71ms ║║Cancelling statement #7’s schedules…
+74ms ║║Executed virtual command parseJson (1ms)
+79ms ║║Executed virtual command setVariable (3ms)
+84ms ║║Comparison (string) Event is (string) playback.unpause = false (1ms)
+86ms ║║Condition #11 evaluated false (5ms)
+87ms ║║Condition group #10 evaluated false (state did not change) (6ms)
+88ms ║╚Execution stage complete. (21ms)
+90ms ╚Event processed successfully (89ms)
