I’d like to avoid having multiple similar pistons if possible, and use a http request from blue iris to call a piston, which will do slightly different things depending on what the http call line says.
Easier to describe with pics, to be honest.
Here are two pistons…
All they do is either set a (virtual) motion sensor (hubitat) to either ACTIVE or INACTIVE, i.e.
or
These pistons currently are called by BlueIris when a camera becomes triggered or returns to inactive.
i.e.
I’m sure there’s a way to combine the two pistons by adding something to the above, and adjust the piston to look for an argument of some type to kind of do
IF (arg1)
then
set active
IF (arg2)
then
set inactive
TIA
(PUT YOUR INFO HERE)
(UPLOAD YOUR IMAGE HERE)
