Passing device variable to a called piston causes device reference to be lost
As suggested by @eibyer, I’ve updated the original post
When a device variable is used as an argument to a called piston, the device reference is messed up.
A device contained in a variable should be usable at both the caller and the called piston.
The called piston cannot access the same device.
Caller piston
Called piston
Caller piston log
Called piston log
I would suggest creating simple test pistons to demonstrate the issue.
done!
I should have done it from the beginning … thanks!
I think this maybe similar but calling the receiving piston differently (using the piston’s external url)
On further trials, it seems the square brackets maybe the issue?
Í think that too.
It’ve noticed that a device reference is always stored in a variable of type device as an array and is surrounded by square brackets like [:dev0:,:dev1:, … ,:devn:]. When it’s an array with a single item, it’s [:dev0:]. However, when passed to a called piston, it’s gets messed up. And I don’t know how to “remove” the brackets, if there’s a way of doing it.
I removed the brackets above using an replace().
Gotcha!
Probably you already know this, since I got the answer analyzing one of your posts:
That’s how I got it working:
CALLER PISTON & TRACE
CALLED PISTON & TRACE
MY DEBUG DATA
MY CONCLUSIONS (if I’m not mistaken … :wink:)
a) to pass a device from one piston to another, I must use a string with the name of the device in it
b) to get a device attribute, use a string variable with the NAME of the device in it using one of the following tested options at tests TEST 2, TEST 4 and TEST 5
c) at the TEST 1 it seems that the string is used instead of the device itself
d) using the device variable surrounded by square brackets notation does not work (TEST 3)
I’m a newbie with WebCoRE and for me it’s a bit confusing how it works, but, it works!
Thanks @eibyer for your help!
I save devices in globals to carry them across pistons.
